£ FREE: steel speaker base plates
Discussion in 'Classified Adverts' started by KUB3, Mar 10, 2006.
  1. KUB3
    KUB3 ciao
    Feb 20, 2006
    278
    A pair of custom made 20mm laser cut solid steel base plates, for use with large speakers or under speaker stands. Could be used as basis for diy stand project. Features M8 metric threaded holes to accept standard speaker isolation spikes (5 holes per plate, for either corner spikes or tri spike arrangement). Black hammerite smooth finish. Overall surface is slightly textured, a bit like an I-beam's finish. Hidden underside is covered in resonance deadening silver dynamat. Each weighs an absolute ton! They were used with some large speakers which are going shortly. W 330mm 13.0", D 465mm 18.3". Going in the skip on 20th march!
    £ FREE to anyone who wishes to collect from Maldon, CM9, Essex.
    KUB3, Mar 10, 2006
  2. KUB3
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Hmmm, I might be interested in these. Let me have a think.
    Dev, Mar 10, 2006
  3. KUB3
    KUB3 ciao
    Feb 20, 2006
    278
    Ok, first refusal to Dev...
    KUB3, Mar 10, 2006
  4. KUB3
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Right, just spoke to the boss, who'll only give me a definitive answer after seeing them. So if it's OK with you I'll ask a colleague of mine who lives near Maldon to pick them up for me. If the boss hates them, I'll offer them to any ZGer who wants them or dump them.
    If you are happy with this please PM me your address. Thanks.
    Dev, Mar 12, 2006
  5. KUB3
    KUB3 ciao
    Feb 20, 2006
    278
    That's fine, you have PM
    KUB3, Mar 13, 2006
  6. KUB3
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Hi Paul/KUB3,
    Still trying to persuade my colleague (who lives in Chelmsford) to make the collection. Not had much luck so far, but I haven't given up yet.
    Dev, Mar 14, 2006
  7. KUB3
    andrewstent
    May 17, 2004
    71
    Speaker bases
    If Dev dosen't go for them in the end could I please have them ?
    Many Thanks,
    Andrew
    andrewstent, Mar 15, 2006
  8. KUB3
    KUB3 ciao
    Feb 20, 2006
    278
    Dev, I'll give you until the end of the month to collect them. If they're still here then I'll say first to arrive can have them.
    KUB3, Mar 15, 2006
  9. KUB3
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    It was good to meet you Paul. Thanks for the plinths.
    Dev, Mar 20, 2006
  10. KUB3
    KUB3 ciao
    Feb 20, 2006
    278
    plinths gone now
    Nice to see you too, on a flying visit!
    KUB3, Mar 20, 2006
