25 watt class A amplifier vs. 220 watt class a/b amplifier
Discussion in 'Hi-Fi and General Audio' started by typewriter12, Jan 2, 2024.
  1. typewriter12
    typewriter12
    Jan 2, 2024
    Present equipment includes a Parasound HCA 2200 power amplifier, rated at 220 watts per channel.
    Speakers are Mirage M5-Si's. Specs from the 'net state their efficiency is 85 db and nominal impedance is 6 ohms.
    A friend has for sale an Eleson PCA 100 power amp (25 watts at 8 ohms, all class A), which apparently resembles a Classe DR-2 power amp.
    The Mirage's are enjoyable because the sound is always 'full'-sounding, with lots of 'body' with instruments or voices, never 'thin'-sounding. That 'fullness' is very important to me.
    I listen only to rock and chill-out music, no classical. Listening volume is always low to medium, never high volumes.
    Preamp is a Mcintosh MA 6200 - used as a preamp only.
    Can the Eleson, while probably a better amp, still provide me with that 'fullness' and 'body'?
    25watts class A vs. 220watts class a/b?
  2. typewriter12
    tuga
    Dec 4, 2006
    324
    3
    Oxenaforda
    If the owner's a friend are you not able to try before buying?
    tuga, Jan 8, 2024
  3. typewriter12
    Arkless Electronics
    Sep 7, 2016
    148
    69
    There is no difference between Class A Watts and Class A/B Watts.
    In practice though most Class A amps are expensive and big and chunky even if only 25WPC, for obvious reasons, but most Class A/B amps that are only in the 20 to 50WPC range tend to be budget or at least lower priced models and everything is done down to a price....including the power supply. Hence the common belief that Class A Watts are "better and more powerful and effortless" than Class A/B Watts.
    As said above try the two amps if it's a friend you are thinking of buying it from and see which you prefer.
    Arkless Electronics, Jan 20, 2024
    tuga likes this.
