4 speakers wire to 4 channels amplifier
Discussion in 'Hi-Fi and General Audio' started by Ced326, Aug 23, 2024.
  1. Ced326
    Ced326
    Aug 23, 2024
    4
    Hi, I just got this Pyle PDA77BU 4 channel audio amplifier, I need to connect 4 speakers(no subwoofer), the user manual lack on how to connect the speakers, here is in the back , each channel has the own volume control know at front
    so here are some of the possible combinations; L-A and L-B or L-A and R-C or other combinations.
    which could be the ideal combination to have the best sound ?, any ideas or suggestions will be greatly appreciated, Thanks
  2. Ced326
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
    I think you're misunderstanding or overthinking this. Each loudspeaker has two wires, a red and a black. Channels A and B go to the left, presumably front and back, and Channels C and D go to the right. Each loudspeaker connects to the terminals as marked. There's no difference in sound quality between the channels. This is a Karaoke amplifier, not a home theatre or HiFi amplifier.
    S
    Sergeauckland, Aug 23, 2024
  3. Ced326
    Ced326
    Aug 23, 2024
    4
    Ok, if it is no difference, great!, you just answered my question, thanks and have a wonderful day!
    Ced326, Aug 24, 2024
  4. Ced326
    Ced326
    Aug 23, 2024
    4
    Hi, still not sure about it, here is picture of different brand 4 channel amp with the same setting than my Amp. and the wiring for 4 speakers is different: one speaker for channel (see the PDF file)? I have connected two speakers at Channel A and the other 2 speakers at Channel C, Which one is the correct connection?
    Ced326, Aug 25, 2024
  5. Ced326
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
    They're both correct. Just make sure that the red terminal on the amp goes to ths red terminal on the loudspeakers. Ditto with the black. Red to Red, Black to black.
    S
    Sergeauckland, Aug 25, 2024
  6. Ced326
    Ced326
    Aug 23, 2024
    4
    ok, thanks again
