4m (13ft) pair Cardas Golden Cross speaker cables
For Sale: Discussion in 'Classified Adverts' started by Snoopdog, Oct 9, 2008.
  1. Snoopdog
    Snoopdog
    Apr 12, 2004
    217
    Hampshire
    Golden Cross is one of their "top of the line" speaker cables. In its standard form it is suitable for any loudspeaker, it is internally bi and tri wireable. This is the reference standard for many speaker manufacturers. 6mm - 1/4" Spades - Standard.
    5.5 awg, Teflon/air dielectric "Golden section" constant "Q", enameled "multi-gauge" "crossfield" "litz" Conductors, Double Hex crossfield cabling urethane jacket.
    Outside Diameter:
    .600
    Dielectric Type:
    Teflon®, Air
    Q Factor:
    23.6
    Inductance:
    .0368 uh/ft/loop
    Capacitance:
    154 pf/ft
    Bi Wire Option:
    Yes
    Tri Wire Option:
    Yes
    Discrete Conductors:
    752
    Cable AWG:
    5.5
    Conductor Type:
    Golden Ratio, Constant Q, Crossfield, Pure Copper Litz
    Excellent condition. Offered for sale at £1199 (way less than half price!).
    Contact Steve on 07725 874832 or 01252 695525 (Fleet, Hampshire).
    [​IMG]
  2. Snoopdog
    Snoopdog
    Apr 12, 2004
    217
    Hampshire
    Photo added!
    "A Top-Notch Performer"
    Top-of-the line Golden Cross speaker cable from Cardas may not be the least expensive cables on the planet. However, "The Golden Cross products deliver a lot for the increase in price over their less-expensive brethren," marvels Dave Duvall in his February 1998 SoundStage.com review.
    George Cardas packs an amazing degree of advanced technology in this interconnect. Golden Cross features patented Cardas "Golden Section," multi-gauge stranding in helical hex array of golden ratio, constant "Q" conductors.It boasts 752 discrete pure copper conductors (for a 5.5 awg.) ensuring full-spectrum signal transfer for unbeatable performance.
    Quashing Cable Resonance
    Patented Cardas "Constant-Q" construction places the smallest of the Golden Ratio strands at the center of the conductor to reduce stored energy and conductor resonance. Cable resonance is further reduced with controlled propagation, Crossfield construction, matching conductor to dielectric characteristics with carefully computed strand layering. Pure Teflon is used as a stabilizing wrap to firmly bind the conductors, while thin tube walls provide the air dielectric to isolate the conductors from each other without accumulating unwanted energy.
    Sonically Colorless
    Golden Reference is sonically colorless, making it a perfectly neutral reference cable. It sounds the same at any length, between any components, at any originating or terminating impedance. It lets you hear the sound of your source material, rather than the sound of a cable. "Golden Cross can easily be considered a top-notch performer," concludes Dave Duvall at SoundStage.com. " Once again, I'm impressed by the Cardas world."
    £1199 ono.
    Snoopdog, Oct 18, 2008
  3. Snoopdog
    Snoopdog
    Apr 12, 2004
    217
    Hampshire
    Now SOLD!
    Thank you Patrick for a smooth transaction.
    Snoopdog, Nov 26, 2008
