I have an LG CM4590 xboom stereo that is 700 watts. The stereo sounds good especially with vocals but I noticed that the sub woofer doesn't need an outlet but uses a plug for the connector so I cut the wire so I could use a different subwoofer to help achieve better lows. Each channel located on the back of the stereo is 3ohms a piece including the subwoofer channel. Will I run into problems using a 4ohm 12 inch speaker? (I have the speaker plugged into the subwoofer channel) [URL]https://www.lg.com/us/speakers/lg-cm4590-mini-shelf-stereo-system[/URL]
