Acoustic Panels - Free / Cheap!
Discussion in 'Classified Adverts' started by Tenson, Aug 30, 2012.
  1. Tenson
    Tenson Moderator
    Nov 12, 2003
    5,947
    Hi Guys,
    I need to clear out, so everything here is free if you pick-up from Gravesend, Kent.
    FREE:
    2 x Pine framed absorber units (white fabric inset) 114 x 114 x 8 cm (WHD).
    These are the nice ones with lacquered frames made by expert carpenters. Should hang on the wall with a hook. They cost a lot to have made! I just don't have a use for them though. The fabric is just on a square frame so could be changed.
    2 x Pine framed diffuser units (white fabric inset) 114 x 114 x 8 cm (WHD).
    As above but diffusors, very nice items.
    [​IMG]
    [​IMG]
    2 x Blue fabric covered absorber units, 109 x 62 x 12 cm (HWD)
    2 x White fabric covered absorber units 123 x 64 x 6 cm (HWD)
    The fabric on these is old and would look a lot nicer with a new cover. They have a wooden frame underneath, so you just need some scissors and a staple gun.
    The deeper units make superb bass traps when placed across the room corners. The 6cm deep units are good for hanging on a wall or could also be placed across corners.
    40x polystyrene diffusors 45 x 50 x 7 cm (HWD). Take as many as you want.
    They are basically like an Auralex MetroFusor (£15 each) but I had them made to my own design. They need to be painted with yacht varnish to make them hard and reflective to sound. You could also paint them first with emulsion to match your room colour. Light weight and easy to put on the ceiling or anywhere else.
    [​IMG]
    4 x White fabric covered absorber units 109 x 109 x 7 cm (WHD).
    Like the pine framed items above but without a visible frame. Just a clean white panel.
    [​IMG]
