amp for b&w 601 s3
Discussion in 'Hi-Fi and General Audio' started by stuartswan, Oct 8, 2007.
  1. stuartswan
    stuartswan
    Jul 6, 2005
    125
    as title i just go these speakers and am looking for an amp to do them justice, how much am i looking to spend and any suggestions, will go second hand probs
  2. stuartswan
    Andy registered grazer
    May 7, 2006
    322
    London.
    No real suggestions but i used to own a set of these speakers and they're very good for the money but the tweeter can get a little harsh when pushed hard so you should be looking for an amp with a smooth top end.
    I had mine on the end of a marantz pm6010ose and found the combination good at normal sound levels but they got a bit hard & brittle when cranked up.
    You're best off getting a home demo so you can have some proper relaxed time to form an opinion on the kit you're trying in familiar surroundings rather than sitting in a dem room on limited time.
    I'd personally try the budget models from Rotel, Arcam, Cambridge Audio and Nad but there's plenty more out there...
    Andy, Oct 9, 2007
  3. stuartswan
    DaveHiFi Seeking Nirvana
    Jan 20, 2006
    126
    Bradford
    I heard these with a Quad 99 / 909 and were kept in check if not a little neutral.
    Dave
    DaveHiFi, Oct 9, 2007
  4. stuartswan
    rollo
    Nov 30, 2006
    339
    N.Y. U.S.A.
    See if you can find a Classe DR25 or Macintosh Amp used. Great synergy with B&W. On the less expensive side the Marantz Recievers do it justice as well
    rollo
    rollo, Oct 11, 2007
