Yes! I also got new amps!!!:D Oh well to say the truth, they are the same as the old ones but refurbished. Both tube mono blocks were sent in december to the states (to Nesti). Diagnostic was: nothing was really working as it should have. :rolleyes: :o Well the Creator made his best, replaced most of the electronic parts (electrolyts, condensators also resistors...) and after a long testing and technical analysing he sent them back to me (I received them last Monday). Well now they are slowly running in and :boogie: :banana: :drum: :band: Now if Graham doens't like the sound he has to blame something else. :D For the next weeks I will be closed in my room upstair listening to music. please do not disturb: :chainsaw: :gatling: So here are the specs: [B]Power Output:[/B] 200 W into 8 Ohms 20Hz to 20kHz [B]Frequency Response:[/B] 20Hz to 20kHz +0, -0.5dB [B]Distortion:[/B] Harmonic-Less than 0.5%, 20Hz to 20kHz at rated power. Intermodulation- Any frequency combination- less than 0.2% [B]Input Sensitivity:[/B] Balanced- 2x 1 volt for rated output Unbalanced - 2 volts for rated output [B]Input Impedence:[/B] 220kohm for each input, to ground [B]Damping factor:[/B] Greater than 20, 20Hz to 20kHz [B]Noise:[/B] wideband, unweighted, greater than 90dB below rated output [B]weight:[/B] 29,5 Kg
