Anyone heard or own one of these?
Discussion in 'Hi-Fi and General Audio' started by speedy.steve, Apr 20, 2008.
  1. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
  2. speedy.steve
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    Why not buy something from a brand not based in a garage in China, from a dealer that has been in existence longer than their promised product warranty.
    sq225917, Apr 20, 2008
  3. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    sq225917, if you have no experience of these why bother answering!
  4. speedy.steve
    alphatoner
    Mar 12, 2007
    141
    Sounds like your in a similar position to me re looking to go for a valve amp. your 3rd one looks similar to this one for sale in the UK at £300 except it's not as bling and 50wpc.
    alphatoner, Apr 20, 2008
  5. speedy.steve
    YNMOAN Trade - AudioFlat
    Jul 16, 2007
    674
    I'm afraid I have no experience of any of them either - but they do all look amazing value for money.
    I've just looked at that one alphatoner posted a pic of and it just has to be by the same people as that ebay one Speedu linked too.
    YNMOAN, Apr 20, 2008
  6. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    I'm in my 6th year of Valve amplification - a project build - see my avitar.
    So I know that components (most are made in China anyway - apart from the tubes and transformers, Swedish in this amp) put together in the right order can sound amazing. Yes the Chinese can solder...
    I want a 2nd unit...
    wow alphatoner you get bio-spheres with it too!
  7. speedy.steve
    Corky 20th Century survivor
    Mar 30, 2008
    129
    Buckinghamshire and soon moving to Yorkshire
    It's a fair point to make sq, and the other rule of ebay - if it looks to good to be true it probably is - also may apply. But... I have noticed some UK companies are now manufacturing in China and my new pre, ASNtrew AT1000, is designed by a UK design and engineering team but they manufacture in China. They're a small outfit and I run the risk of them not being there just because they're a relatively young business, but I get a lot for my money and cannot find any hint of poor construction or build - on the contrary. If I was in the market for a CD player I'd definitely look a the ASTINtrew machine. China doesn't have to be a problem if the work is manufactured to high standards.
    Corky, Apr 20, 2008
  8. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    "But... I have noticed some UK companies are now manufacturing in China"
    Indeed. The Beresford DAC is Taiwan I believe? - Cracking product for the price. Punches well above it's weight.
  9. speedy.steve
    mhuk easily distracted
    Mar 24, 2006
    50
    Midlands
    And Audiolab are probably a more well known company who manufacture in China.
    Here's a brand with a big garage in China, and it's by the sea :)
    [​IMG]
    mhuk, Apr 20, 2008
  10. speedy.steve
    alphatoner
    Mar 12, 2007
    141
    and that means :confused:just trying to prove my ignorance
  11. speedy.steve
    Mar 30, 2008
    129
    I think he means the shiny globes on your link:
    :D :D :D
    Corky, Apr 21, 2008
  12. speedy.steve
    Valve Bob
    Apr 27, 2008
    P88i amp
    Looks a bit cheap but do not be deceived. Remove the bottom plate and see how neatly it has been assembled, remember it's hand-made!
    I own one. I have been chopping and 'upgrading' on an ongoing basis until I got this amp. It's a keeper. I WILL NOT CHANGE AGAIN.
    My speakers are made by a local genius ( South Africa ) SONOR AUDIO VEGA's @ 26Kg each and compare with audio of speakers double the price. Don't know whether they are available outside South Africa.
    Check out SONORAUDIO.COM
    The Vega's are 6 ohm & when connected to the 4 ohm of the P88i
    sound brilliant.
    When I win the lotto I will upgrade to the SONOR CAPELLA speaker, but that's a seperate issue.
    The P88i amp will not disappoint - I love classical jazz, bass definition is a priority. I am not sorry I bought the amp.
    Hope this helps.
    PS. Consider the vagina; might look a bit dodgy, but it works beautifully!
    THE DEFENCE RESTS.
    Valve Bob, May 6, 2009
  13. speedy.steve
    Mar 30, 2008
    129
    that explains my hi fi trouble then... :D
    Corky, May 7, 2009
