are ther non-contentious benefits to aftermarket power cords?
Discussion in 'Hi-Fi and General Audio' started by Coda II, May 26, 2009.
Thread Status:
Not open for further replies.
  1. Coda II
    granville
    Feb 11, 2006
    138
    The edge of reality
    I imagine David is suggesting that heavy oxidation on the contacts will result in an increase in the impedance and therefore
    reduced current carrying capacity within the circuit.
    granville, Jun 4, 2009
    #41
  2. Coda II
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Thank you.
    DavidF, Jun 4, 2009
    #42
  3. Coda II
    lAmBoY Lothario and Libertine
    1,233
    At home
    rusty contacts will do that. A tad of smegma from normal use over the years wont.
    lAmBoY, Jun 4, 2009
    #43
  4. Coda II
    granville
    Feb 11, 2006
    138
    The edge of reality
    wrong again.
    I can test circuit impedance on a socket using my Megga MFT1552
    then clean the contacts on the plug and re test, the result is
    a reduced impedance.
    What I have not said is that this will produce an audible difference,
    merely that it will make a difference to the current that can flow within the circuit.
    #44
  5. Coda II
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Yes it will.
    Polish the contacts up so they are bright and shiny.
    You DO notice the difference..
    DavidF, Jun 4, 2009
    #45
  6. Coda II
    Soloist In my lonely furrow
    Mar 12, 2009
    191
    Peterborough, UK
    Well, I am reltively new to all this and I didn't even take physics at O level but just by way of observation:
    When we took the caravan out a couple of weeks ago( yes, sorry, I'm one of them), having not used it for about six months we had all sorts of funny things going on with the lights. Now, a quick celan up of all the bulbs' contacts and the plug/socket at the car end sorted things out perfectly. Ok, so we are talking about 12v rather than 240v but the currents are also much lower. Oxidation makes a significant difference in this simple electrical system.
    Having said all that, I havn't been moved to shine up my mains yet!
    Any non-contentious benefits? er, no.
    Soloist, Jun 4, 2009
    #46
  7. Coda II
    stereotype
    May 21, 2009
    79
    If you have mains fuses, try cleaning the power socket fuse and its socket. Turn off the house switch first, of course. Safety first.
    stereotype, Jun 4, 2009
    #47
  8. Coda II
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    No unfortunatley it continues to be a pointless cause of debate.
    Try it and see what you think!
    I don't know why some members are so anti. I shoiuldn't have thoiught it was that provocative.
    DavidF, Jun 4, 2009
    #48
  9. Coda II
    stereotype
    May 21, 2009
    79
    Anyone would think we were demanding money with menaces! :)
    #49
  10. Coda II
    1,233
    At home
    again? where was the first time? :S
    I don't hear any change in sound after a clean. Maybe my pins aren't grubby enough.
    lAmBoY, Jun 4, 2009
    #50
  11. Coda II
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    No, we've just had one or two silly people on the forum.
    DavidF, Jun 4, 2009
    #51
  12. Coda II
    tuga
    Dec 4, 2006
    324
    3
    Oxenaforda
    How about going on a pilgrimage to Lourdes with a hard to keep promise? :confused:
    tuga, Jun 4, 2009
    #52
  13. Coda II
    1,233
    At home
    A few silly folk, a few loons and a few noobs. Thats why we all like ZG so much!
    lAmBoY, Jun 4, 2009
    #53
  14. Coda II
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    I don't believe this is ever going to be significant. How much reduction in impedence is there, generally?
    In any case, my plug pins are not subject to "heavy oxidation".
    The Devil, Jun 4, 2009
    #54
  15. Coda II
    stereotype
    May 21, 2009
    79
    Why don't you clean them? Have a good listen to a particular work, one with plenty of dynamics, clean the L and N pins of a component, listen again to the same work. Then clean the earth pin, listen again. Tell us if you hear any differences. If you are prepared to clean the socket contacts (wrap some emery paper round a thin file or similar, having ensured that the socket is isolated), the better the test.
    #55
  16. Coda II
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    Because I think it's a waste of time.
    #56
  17. Coda II
    stereotype
    May 21, 2009
    79
    How much time?
    #57
  18. Coda II
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    Any time.
    It's also a waste of money.
    #58
  19. Coda II
    RobHolt Moderator
    Oct 24, 2004
    Yes they look shiny.
    RobHolt, Jun 5, 2009
    #59
  20. Coda II
    stereotype
    May 21, 2009
    79
    Try it.
    stereotype, Jun 5, 2009
    #60
Thread Status:
