Asus Xonar Essence STX soundcard
Discussion in 'Hi-Fi and General Audio' started by Labarum, Nov 20, 2010.
  1. Labarum
    Labarum
    Oct 18, 2008
    492
  2. Labarum
    RobHolt Moderator
    Oct 24, 2004
    9
    Titter
    RobHolt, Nov 20, 2010
  3. Labarum
    Labarum
    Oct 18, 2008
    492
    Well what else is audio-nervosa about, Rob, but choosing your preferred colouration?
  4. Labarum
    6,026
    Beyond the 4th Dimension
    Hi Labarum,
    I have had experiance with these cards, and they do offer good performance for the outlay without question. It will surprise you.
    Have even upgraded the odd one or two.
    wadia-miester, Nov 21, 2010
  5. Labarum
    RobHolt Moderator
    Oct 24, 2004
    9
    Yes but it's a sound card. Good op amps cost peanuts and the correct op amp is the one that does the job correctly. You cannot just swap around with no understanding of the circuit in which they operate. The designer ought to use the device that gives the best performance.
    Nothing wrong with preferred colouration but do it where you have some real control - use effects software or hardware solutions. You can then apply the 'colouration' you desire at will depending on what you are actually listening to.
    This looks to me like a mainstream computer accessory company taking advantage audiophile audio-nervosa.
    RobHolt, Nov 21, 2010
  6. Labarum
    uglymusic
    Jun 22, 2010
    18
    By the sea
    I've listened to an Asus Xonar card at length, and it's pretty impressive.
    I think you need to be careful with the PC environment you put it in for best results - ie don't just stick it in your Dell desktop and expect the best.
    uglymusic, Nov 22, 2010
  7. Labarum
    RobHolt Moderator
    Oct 24, 2004
    9
    Dave, is this the card that Jason was using in the 'you know what'?
    If so, it sounds very good.
    RobHolt, Nov 22, 2010
  8. Labarum
    uglymusic
    Jun 22, 2010
    18
    By the sea
    Indeed it was!
  9. Labarum
    Labarum
    Oct 18, 2008
    492
    A little clarification of "you know what" perhaps?
    Labarum, Nov 23, 2010
  10. Labarum
    uglymusic
    Jun 22, 2010
    18
    By the sea
    It's a product that's under development. I understand it should be available soon.
    uglymusic, Nov 23, 2010
  11. Labarum
    RobHolt Moderator
    Oct 24, 2004
    9
    Oh, if we must :)
    The new NVA streaming solution. I don't beleive it has a name yet.
    Prototype sounds good.
    RobHolt, Nov 23, 2010
