Atmospheric Conditions and Sound
Discussion in 'Hi-Fi and General Audio' started by Soloist, Jan 13, 2010.
  1. Soloist
    Soloist In my lonely furrow
    Mar 12, 2009
    191
    Peterborough, UK
    Not having studied physics, I found myself wondering if barometric pressure has any direct effect on sound, for example, is 1 bar required to accurately test the sensitivity of loudspeakers?
    Ta! :)
  2. Soloist
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    In theory, yes:). At zero bar no one can hear you scream:D.
    Dev, Jan 13, 2010
  3. Soloist
    Mar 12, 2009
    191
    Peterborough, UK
    Ah, yes, of course! Not that the small differences in atmospheric conditions 'ere on earth will make that much difference. Does tone change with air pressure? or is it just volume?
  4. Soloist
    felix part-time Horta
    Dec 13, 2003
    757
    dead
    Tone is (mixes of) frequency, and that does not change with air pressure. Neither, interestingly, does the speed of sound (varies less than 2% for span of zero to 100% relative humidity around room temp IIRC).
    Sound pressure level (volume) and barometric pressure aren't realy linked at all - the first is simply a minute local variation in the latter. Then again you can't really hear 'DC' - barometric pressure.
    Extreme variations might cause small change in performance for some speakers though: for example back when Stereophile was based in Santa Fe (very dry, >8000ft above sea level, so lower baromteric pressure) they found that ESLs would arc a bit more readily than expected IIRC...
    felix, Jan 13, 2010
  5. Soloist
    nando nando
    Jun 1, 2006
    4,017
    london
    No Diference On Sound Here, Infact Sounds Quite Nice,
    Nando.
    nando, Jan 13, 2010
  6. Soloist
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Yup, only the temperature affects it "significantly". I found this link to calculate approximate speed of sound, just in case you were curious or had mislaid the formula:).
    For the original question, I'd say the differences aren't worth spending time on ;).
    Dev, Jan 13, 2010
