Attenuation
Discussion in 'DIY Discussion' started by stumblin, Dec 29, 2003.
  1. stumblin
    stumblin Kittens getting even...
    Oct 24, 2003
    350
    California!!!
    Anyone had any experience attenuating a balanced cable?
    Any thoughts? I'm not paying £69 for a Rothwell balanced attenuator, and I don't want to change my cable if I can avoid it.
    I've got about 5 degrees usable volume control and it's starting to seriously nark me off.
  2. stumblin
    Oct 24, 2003
    350
    California!!!
    My thoughts are:
    39KOhm in series on the hot wire, and then a 9K1 shunt between hot and signal return. This should give about 16dB, should it not?
  3. stumblin
    1,118
    by the cross
    if its fully balanced youll need to do the same to the - (pin 3 on xlrs) wire,if you use a couple of pots you can find the ideal values and then replace them with fixed resistors
    themadhippy, Dec 29, 2003
  4. stumblin
    Oct 24, 2003
    350
    California!!!
    I'm not really sure. Reading through the manual NAD refer to the - pin as 'signal ground'. Implying that it's not + and - as such as just having a seperate signal ground to the sheild.
    In your method I presume you'd put a series resistor in + and - and then a shunt between + and shield and - and shield, right?
  5. stumblin
    Oct 24, 2003
    350
    California!!!
    The manual says this:
    Pin 1 : Chassis Earth (Ground)
    Pin 2 : Hot (Live)
    Pin 3 : Signal Ground (Return)
  6. stumblin
    1,118
    by the cross
    yep,but the discription given by nad makes it look like its not a balanced system,so your origanal idea will work
  7. stumblin
    Oct 24, 2003
    350
    California!!!
    Well, it would appear that my DIY skills haven't totally deserted me (see mains filter thread).
    Just finished attenuating my cable and it works a treat. There is a slight improvement in the sound, mainly because my amps tonal balance seems to change slightly as it moves away from minimum volume (I was previously always near minimum, unless I fancied a bit of ear bleeding). Now I can run around the dial a bit more and listen at normal levels with the tonal balance I 'enjoyed' at the higher levels. Basically the bass is in better proportion at lower volumes.
    Having said all that, I could be making it all up in my head - but I don't care. The attenuation served it's primary purpose of giving me more range on the volume control, meaning I can now realistically use the remote to adjust volume.
    Woo hoo.
    stumblin, Dec 30, 2003
