Hi Everyone, Somewhat new to forums so sorry if I get anything wrong. I'm looking for some help with an audio system on a 10m boat I am getting very loud hum over the speakers when high powered led lights are on I have a fusion head unit and 8 speakers, 2 amps. I have tried re routing cables and also tried a cable moved away from the main cable runs with one speaker and everything else disconnected and still getting noise. I have also tried an isolated power supply but that hasn't helped as I believe its noise from the led lights that are causing the problem. I am going to try to run a spare rca cable across from the amp to the head unit tomorrow with just my one speaker connected and see if I still get the noise even when the cable is away from the led cables. Just wondering if there is anything else I can try or if there is some grounding or suppression I'm missing. Thanks in advance for any help!
