Hi all, I would appreciate your experienced advice on the following: I may be acquiring an Audio Technica AT-OC9 MC cartridge to fit on my pink triangle (through an RB300) although I'm not sure how old it is and how much use it's had. My conundrum is that I'm currently using an almost brand new Grado Gold which I really like the sound of. Another consideration is that the phono stage I use is the in-built one in my Arcam Delta 90.2 amp and, whilst this is switchable to MC, I appreciate that it's not an expensive and sophisticated phono stage and MC's have a far lower output and therefore require far more and better quality amplification to get the best out of them than MM's (or moving iron's in the case of the Grado). Unfortunately, buying an external phono stage isn't an option, so I'd be interested to hear your thoughts and experience if any of you have previously owned an AT-OC9. Thanks, Wolf Thanks, Andrew
