B&W DM602S3
Discussion in 'Classified Adverts' started by cookiemonster, Oct 7, 2003.
  1. cookiemonster
    cookiemonster
    1,316
    Berkshire
    These are in super immaculate condition, and taking into consideration the nicely run in bass/mid driver, i would not hesitate to venture that they are in fact better than 'as new':)
    Original boxes, packaging, grilles, jumpers, manual etc. All in spotless condition.
    These are offered for collection only, or delivery within a reasonable distance.
    £195
    Description 2-way vented-box system
    Dimensions Height: 490mm (19.3in)
    Width: 236mm (9.3in)
    Depth: 293mm (11.5in)
    Net Weight 10.5kg / 23.1lb
    Freq. Response 49Hz - 22kHz ± 3dB on reference axis
    Freq. Range -6dB at 40Hz and 42kHz
    Sensitivity 90dB spl (2.83V, 1m)
    Nominal Impedance 8 ohms (minimum 3.0 ohms)
    Power Handling 25W - 120W into 8 ohms on unclipped programme
    Drive Units Unit 1: 1x 25mm(1in) metal dome high-frequency
    Unit 2: 1x 180mm (7in) woven Kevlar® cone bass/midrange
    Finish Cabinet: Sorrento (light oak) vinyl
    Grille: Black Cloth
    Dispersion Description: Within 2dB of response on reference axis
    Horizontal: over 40° arc
    Vertical: over 10° arc
    Harmonic Distortion 2nd & 3rd harmonics <1% 60Hz - 20kHz (90dB spl, 1m)
    Crossover Frequency 4kHz
    Cable Impedance 0.1 ohms
    [​IMG]
    Reviews:
    http://www.bwspeakers.com/index.cfm/fuseaction/products.reviews/Label/Range 600 Series 3
  2. cookiemonster
    cookiemonster
    1,316
    Berkshire
    SOLD :)
    cookiemonster, Oct 10, 2003
  1. For Sale: B&W DM602s3
