Baffling Ebay
Discussion in 'Hi-Fi and General Audio' started by Joolsburger, Sep 4, 2003.
  1. Joolsburger
    Joolsburger
    510
  2. Joolsburger
    Goomer
    Sep 1, 2003
    598
    Mine doesn't have that groovy handle(pun kinda intended) or green lined box - don't think I'd pay an extra £8.00 for them though. Is this one of those occasions where a product may be hugely more expensive in other shores, so paying over the odds on ebay is actually a good deal?
    Goomer, Sep 4, 2003
  3. Joolsburger
    5,139
    Manchester
    Goomer where did you get yours from and does it work? I could do with cleaning some of my records, some of them are twice as hold as me.
    amazingtrade, Sep 4, 2003
  4. Joolsburger
    Goomer
    Sep 1, 2003
    598
    As Joolsburger said, www.vivante.co.uk - if you have a look at the vinyl accessories section there's a catalogue that you can download as a pdf file, and, from memory, I think the Nagaoka roller is at the top of the list.
    Hope that helps,
    Goomer.
    Goomer, Sep 4, 2003
  5. Joolsburger
    5,139
    Manchester
    Yep thanks it helps a lot, I always thought the even the basic cleaners cost a fortune.
  6. Joolsburger
    Markus S Trade
    1,527
    Nether Addlethorpe
    The Nagaoka doesn't work at all well. Better to spend your hard-earned on a cheap record cleaning machine like the Knosti disco antistat. If that's too much hassle, get a carbon fibre brush.
    Markus S, Sep 4, 2003
  7. Joolsburger
    Joolsburger
    510
    The Nak is good enough for removing dust and fluff from a record but won't deep clean. I use one all the time and find it better than a carbon brush. can build up static though if you go too fast.
    Joolsburger, Sep 5, 2003
  8. Joolsburger
    Markus S Trade
    1,527
    Nether Addlethorpe
    The Nagaoka only cleans the top surface of the record, which is okay if you have a lot of fluff etc. on it. The carbon fibre brush will also clean the groove itself. Works better for me.
    Markus S, Sep 5, 2003
  9. Joolsburger
    Joolsburger
    510
    I find the brushes just move the dust around whereas the roller picks it up.
    As for the grooves I can't see that well!! Sounds okay to me though.
  10. Joolsburger
    Hodgesaargh
    Aug 24, 2003
    323
    Edinburgh
    I use caustic soda and a wire brush and it gets everything off. :MILD:
    Hodgesaargh, Sep 5, 2003
