Why do we hi-fi buffs keep experementing? I bought a Chord 64 in early December and have concluded that it stays:cool: As it happens, I also use a Chord Phono Stage which I have used in balanced mode (turntable is AC Orbe + SME V + Lyra Dorian) feeding into a Sugden Masterclass Pre and a pair of Masterclass Monos. Result? :JPS: So my problem? Well my former DAC had no balanced outputs, and I auditioned the DAC 64 in the same way. However, tonight I decided to use my balanced interconect (KIMBER KCAG) to link my DAC 64 to the pre amp. Result is jaw droppingly good. I am amazed at the improvement. However, the Sugden Masterclass has only one balance input - and I can't sacrifice the vinyl front end. So what would you advise? Swap the cable every time I move from Vinyl to CD:rolleyes: ? Go back to the phonos on the DAC 64? Would swapping the balanced cable all the time damage the outputs in the Chord Phono Stage and the DAC 64? Help, please;)
