Balanced Line
Discussion in 'Hi-Fi and General Audio' started by Richard Dunn, Oct 24, 2010.
  1. Richard Dunn
    Tenson Moderator
    Nov 12, 2003
    5,947
    Balanced outputs are often less noisy because of using two op-amps to drive them and giving a higher signal level, producing a -6dB reduction in noise floor comparative to using one op-amp.
    Tenson, Oct 25, 2010
    #41
  2. Richard Dunn
    Richard Dunn
    Jul 5, 2006
    1,198
    Please note I said balanced line = line level. If a signal doesn't reference to something there is no signal.
    Richard Dunn, Oct 25, 2010
    #42
  3. Richard Dunn
    flatpopely Trade - AudioFlat
    Jun 20, 2010
    273
    York
    The reference is the other signal in balanced operation be that at line, mic or whatever level, not gnd.
    flatpopely, Oct 25, 2010
    #43
  4. Richard Dunn
    Richard Dunn
    Jul 5, 2006
    1,198
    You said the signal wasn't referenced!!!!
    #44
  5. Richard Dunn
    Jun 20, 2010
    273
    York
    Now who is playing games. I meant not referenced to ground. Balanced operation requires two conductors not three, word games don't avoid that engineering fact.
    #45
  6. Richard Dunn
    Richard Dunn
    Jul 5, 2006
    1,198
    Then you try sending a signal down 50ft of cable without a screen and ground.
    #46
  7. Richard Dunn
    Jun 20, 2010
    273
    York
    Seems to work on my phone line OK?
    Might I suggest you read up about balanced operation as you clearly do not fully understand what it is.
    #47
  8. Richard Dunn
    Labarum
    Oct 18, 2008
    492
    Yep, that what he said.
    "Not . . . referenced to ground."
    Me? Applied Physics and electronics 40 years ago at Durham University.
    Labarum, Oct 25, 2010
    #48
  9. Richard Dunn
    Richard Dunn
    Jul 5, 2006
    1,198
    So why does every *audio* cable used in studios and PA rigs have two cores and a screen and the screen is earthed.
    #49
  10. Richard Dunn
    Jun 20, 2010
    273
    York
    To stop external noise getting into the signal but it has nothing to do with balanced operation.
    #50
  11. Richard Dunn
    Labarum
    Oct 18, 2008
    492
    Is there any evidence that a pair of conductors in a screen for an unbalanced cable is any better than a single conductor in screen?
    #51
  12. Richard Dunn
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    More epic facepalm activity from richard once again,.
    sq225917, Oct 25, 2010
    #52
  13. Richard Dunn
    Jun 20, 2010
    273
    York
    I suspect an apology for the error will not be forthcoming or an admission that he was wrong either.
    #53
  14. Richard Dunn
    Jun 20, 2010
    273
    York
    Twin conductors (signal and earth) surrounded by a screen should have greater immunity to RF noise. Does that mean it will sound better, I don't know but it will mean it has less RF noise than a cable without a screen.
    #54
  15. Richard Dunn
    Richard Dunn
    Jul 5, 2006
    1,198
    Per usual you two are getting into personal game playing. The thread no longer serves an information process, it serves your desire for conflict
    1/ I admit I didn't realise a cartridge would naturally balance, or that other manufacturers were using that property, which I have admitted. To want an apology for that is game playing.
    2/ I stated that a signal doesn't exist unless it references something, you said in your post it is not referenced to earth. I did not say it didn't reference the other leg, what is there to apologise for.
    3/ Without a screen a lead is wide open to RF pick up whether it is two cables or one balanced or not, it then relies on the differential circuit to null it, some of them don't which is why a cable screen in *all* pro application is normal and considered a necessity.
    end of.
    #55
  16. Richard Dunn
    RobHolt Moderator
    Oct 24, 2004
    That is surely the important element in all of this.
    It is a trade-off.
    What you have to consider is the following:
    Low noise, low hum, low distortion, high input margin single ended phono stages exist and have done for many years. Vinyl as a source has a very high noise floor and dynamic range is limited to around 50db. Distortion barely gets better than 1% and is considerably higher at HF - going into double figures. Improving the front end interface performance by a dB or two is entirely moot. As mentioned above, you also risk more self noise from the stage so might actually end up in a worse position.
    When it comes to line level connections it is difficult to see any benefit unless using long cables.
    In short, other than in certain very specific instances it does little to enhance performance and can actually make it worse.
    RobHolt, Oct 25, 2010
    #56
  17. Richard Dunn
    Jun 20, 2010
    273
    York
    1/ I dont want an apology I merely said one would not be forthcoming.
    2/ Re read the thread.
    3/ You are correct, no screen means more noise. However the fact remains that a balanced connection needs two wires and not three as you stated.
    I would suggest that due to the rather 'robust' posting style you employ and the fact you were in error people might take things you say in future with a pinch of salt. A more 'relaxed' posting style might be in order. Just some advice to which you can apply the term 'marmite'.
    #57
  18. Richard Dunn
    RobHolt Moderator
    Oct 24, 2004
    Richard I have delted your last post as its way out of order.
    What Andrew makes and how he sells it has absolutely nothing to do with this discussion.
    #58
  19. Richard Dunn
    Richard Dunn
    Jul 5, 2006
    1,198
    He is trying to assassinate my character, so he got some back, tit for tat, which is my usual reaction to him. You remove one side and all you leave is his tit, or more applicable his tat unchallenged.
    #59
  20. Richard Dunn
    Jun 20, 2010
    273
    York
    Oh dear!
    #60
