Pure Hardwire provides a simple and elegant means to enhance connections from conventional hi-fi equipment to the mains supply. It replaces the usual multiple 13A or IEC connector plugs and socket banks, with the reduced inter-metal count of hard wired connections. Pure Hardwire comprises a solid, non-magnetic, sand cast terminal box, that will provide RF shielding. Equipment connection employs compact, high quality terminals with proper conductor clamping (where high pressure doesn't chop the wire in half), long used for permanent power distribution. Even National Grids vital 400KV switching control electronics relies on them!
