Benz Micro LP Ebony
Discussion in 'Hi-Fi and General Audio' started by The Devil, Aug 29, 2008.
  1. The Devil
    robM
    Feb 6, 2004
    347
    well if it helps the sales of that phonostage as well as those horn thingys you have increase...then yes it was a figment of my imagination NOT!:D
    robM, Sep 7, 2008
    #81
  2. The Devil
    Purite Audio Purite Audio
    Nov 25, 2006
    1,250
    For every time She shouted 'fire!'
    They only answered 'Little Liar'.
    Purite Audio, Sep 7, 2008
    #82
  3. The Devil
    hifi addict
    Sep 26, 2006
    505
    Hastings
    Is that a quote from Lizzie Dripping?
    hifi addict, Sep 7, 2008
    #83
  4. The Devil
    Paul Ranson
    Sep 4, 2003
    1,602
    An octopus's garden.
    This sounds like nonsense.
    Do you know what 40dB means?
    Paul Ranson, Sep 7, 2008
    #84
  5. The Devil
    Nov 25, 2006
    1,250
    'Matilda' from Hillaire Belloc's 'Cautionary Verses' ( for forum posters) Are you back?
    #85
  6. The Devil
    hifi addict
    Sep 26, 2006
    505
    Hastings
    I'm back in blighty for a month then back to crete in October. So when are you going to invite me to have a listen to the new speakers?
    hifi addict, Sep 8, 2008
    #86
  7. The Devil
    Nov 25, 2006
    1,250
    Last of the famous international playboys.
    Purite Audio, Sep 8, 2008
    #87
  8. The Devil
    robM
    Feb 6, 2004
    347
    Quote P RansonThis sounds like nonsense.
    what part of it sounds like nonsense? The filter stage between 2 gain stages or the fact that trichord etc use the technique?
    I think the actual schematic originally came out of a Burr Brown application note for one of their ICs. Since then Michell, Trichord, TE and a whole load of them have been using it.
    Doesn't MM require a gain of approx 40dB? and MC between 55 and 70dB depending on the MCs output.
    robM, Sep 9, 2008
    #88
  9. The Devil
    Paul Ranson
    Sep 4, 2003
    1,602
    RIAA puts 20kHz 40dB lower than 20Hz. So a fully passive eq has to amplify 20kHz 40dB more than eventually required. 40dB is 100times. With opamps this really seriously compromises the overload margin and in the real world scratches and clicks will cause unpleasant effects due to overload. So I doubt that a real world manufacturer would implement this.
    It's quite common to put active bass eq around one gain stage and then passive treble cut before a second. OTOH I think the app note circuit in http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1154,C1009,C1026,P1293 has been used by some well regarded products. Fully active EQ FWIW.
    Paul Ranson, Sep 9, 2008
    #89
  10. The Devil
    robM
    Feb 6, 2004
    347
    Yes, I understand the math as I have built enough of them over the years. Page 12 of the LT1115 app sheet shows the schematic which Trichord, TE, Michell, Lehmann and many others use. This is a basic copy of the Burr Brown circuit and the filter section has been talked about by the great Walt Jung. It really is a cheap method but you can get around some of the basic problems easily. In terms of audio quality.... I'm not a fan.
    http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1154,C1009,C1026,P1293,D1612
    This is where you'll find the original (I think)
    http://focus.ti.com/lit/ds/symlink/opa606.pdf
    It's the last circuit which uses a fully passive RIAA.
    Hybrid filter circuits on the other hand are much harder to implement for all gains. Whest, Neve and Boulder do it because they have designed their own discrete circuits. But the component count is much much more which is why most manufacturers use ICs.
    ICs are generally used to cut down costs. If it were about audio quality then all the BIG high-end stuff would use AD797 and LT1028s or AD825s, but they don't.
    robM, Sep 10, 2008
    #90
  11. The Devil
    robM
    Feb 6, 2004
    347
    Paul. ( I know this thread has gone off topic a tad)
    Read the tech sheet for the Lehmann Black Cube.
    http://www.lehmannaudio.de/download/info/pdf_screen/EN_black_cube_statement_screen.pdf
    The passive eq is the same one. Yes it is that easy to do it. I built my first passive stage in 1982. Using 2N4401s and 5534 in the input section - then fully passive - then a NE5534 and 550/560 pair for current output. Back then I managed to get the curve to within +/- 0.4dB at 63dB level 20hz-20Khz.
    After you do many of these things you soon realise that the curve accuracy makes up about 4% of the audio quality. Even getting it down to +/-0.15dB at my 63dB made no difference. What makes the difference is when you go discrete and use active RIAA for part of it.
    Anyway... the Benz Ebony is great Devil :D
    robM, Sep 10, 2008
    #91
  12. The Devil
    anon_bb Honey Badger
    May 30, 2005
    2,804
    Tom evens uses lt1028 and ad797 - plenty of others use ad825. The ad8065 is even better ;)
    anon_bb, Sep 10, 2008
    #92
  13. The Devil
    robM
    Feb 6, 2004
    347
    Ever listened to a Boulder 993 module compared to a 8065? or even simpler.... listen to an API channel strip with all the discrete opamps changed over for ICs.
    When you get into the bigger league it's all discrete.
    robM, Sep 10, 2008
    #93
  14. The Devil
    May 30, 2005
    2,804
    I don't doubt discrete is better - I refuse to have any opamp in my signal path - however a lot of high end kit does use them.
    #94
  15. The Devil
    Nov 25, 2006
    1,250
    Ever heard a really good LCR eq?
    Purite Audio, Sep 10, 2008
    #95
  16. The Devil
    hifi addict
    Sep 26, 2006
    505
    Hastings
    LCR is very difficult to do at any reasonable price. I know a couple of manufacturers who have tried but the cost has spiraled. The results are supposed to be fantastic. Op amp phonostages can be very good in MM stages. I like the firestone audio Korora phonostage. In MM mode it is one of the best I have heard. In MC mode it's good but I would pay the extra for an LCR or suchlike.
    Another way of doing it is to use a MM phonostage with a decent step up transformer. The only problem with that any unwanted noise is amplified. So careful matching is needed.
    If I were to buy a phonostage now i would buy an FM acoustics 122 or 222 phonostage.
    hifi addict, Sep 10, 2008
    #96
  17. The Devil
    robM
    Feb 6, 2004
    347
    For-ge-abou-it :MILD:
    robM, Sep 10, 2008
    #97
  18. The Devil
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    Good to see Elbow win the MMP with Seldom Seen Kid. A superb record on all levels, IMO.
    The Devil, Sep 10, 2008
    #98
  19. The Devil
    Paul Ranson
    Sep 4, 2003
    1,602
    I'm so out of touch I'd never heard of them.
    Paul Ranson, Sep 10, 2008
    #99
  20. The Devil
    Paul Ranson
    Sep 4, 2003
    1,602
    I don't understand why you think it is 'easy' in a way that active or active/passive eq isn't?
    There are lots of good reasons not to use passive eq, I can't think of any positives but I'm open to offers.
