Best HiFi rack shelve material ?
Discussion in 'DIY Discussion' started by sastusbulbas, Jul 16, 2006.
  1. sastusbulbas
    sastusbulbas
    May 21, 2006
    275
    Edinburgh
    After reading the best speaker enclosure material, I started wondering what would be the best material for replacing shelves on an old Target or Apollo rack , around 15mm to 18mm thick and capable of supporting some weight ?
  2. sastusbulbas
    dean.l
    May 1, 2006
    194
    acrylic would be good but prohibitively expensive.
    you could try a mix of mdf, ply and bitumen, if made up slightly bigger you could sand the edges for quite a nice finish.
    dean.l, Jul 16, 2006
  3. sastusbulbas
    AlexTaylor
    Nov 13, 2005
    163
    Definitely acrylic.
    AlexTaylor, Jul 16, 2006
  4. sastusbulbas
    MartinC Trainee tea boy
    Aug 27, 2003
    995
    Southampton
    Out of curiousity, why?
    MartinC, Jul 17, 2006
  5. sastusbulbas
    dean.l
    May 1, 2006
    194
    low resonance, it looks nice etc, but is silly money in that thickness.
    I should think the mdf etc will be as good, and could look nice too, oh and will be cheap to boot.
    or just leave the glass + focal pods? don't see why not.
    but I guess the original question was what is the best. acrylic should be the best if cost is not a problem.
    then again if that is the case buy a load of mana wall shelves, ugly but better isolation that a rack. because of the floor not being directly coupled with the wall etc.
    dean.l, Jul 17, 2006
  6. sastusbulbas
    1,196
    Sunny Cheshire
    I dispute that a rack on a solid floor is inferior to a wall shelf fixed to a stud wall bouncing around as a passive radiator!
    Bob McC, Jul 17, 2006
  7. sastusbulbas
    mosfet
    Jan 1, 2005
    387
    Another one of my never-got-round-to-finishing projects. Composite honeycomb board - sometimes referred to as aerolam given its usage in the aviation industry. High stiffness to weight ratio. Expect to pay around £50 for a sheet sufficient to make a rack shelf from.
    http://www.plascore.com/
    http://www.coretexgroup.co.uk/
    [​IMG]
    mosfet, Jul 18, 2006
  8. sastusbulbas
    Garmt
    Apr 26, 2005
    557
    I would use simple thick plywood.
    Garmt, Jul 18, 2006
  9. sastusbulbas
    dean.l
    May 1, 2006
    194
    well maybe, but no mention of material for walls was mentioned, or floors for that matter, so I assumed brick or block, there is normally an outside wall availabe in most rooms, so I would still go for the wall rack for the best isolation, I have a normal target 6 shelf rack btw
    just a 2" thick piece of solid pine hollowed out and filled with lead sheet and silicone sealant, under the preamp. this combination of lead and wood is very dead sounding, but is way too thick to be used on anything but the thinnest of equipment.
    anyway I am quite happy with the isolation this offers as it is on a concrete floor and on spikes, but if I had problems I would use a wall mount for sure.
    dean.l, Jul 18, 2006
  10. sastusbulbas
    kenneth cooke
    Feb 23, 2006
    37
    Yorkshire West Riding
    Audio Racking
    I bought a 4 shelf set of Quadrasphere shelving second hand for £150. I believe that they can be have secondhand from various dealers. Quadrasphere units are superb
    kenneth cooke, Jul 20, 2006
  11. sastusbulbas
    zanash
    3,826
    Notts.
    So a few suggestions.......
    for my two pence worth, I'd look to combine 2 x 6mm mdf with a 18mm stiff light foam centre[foamed butyl rubber]. This has given me a very rigid light shelf that has the ability to damp the higher freqs getting back into your kit. This is easily tested using a stethescope [...go ask your doctor for an old one....as they get them free from drug companies]. use a ball bearing 10-15mm dropped from say 15cm on to the floor[no carpet]. listen first to the floor ,then the rack, then the old shelf and then the new one ....I was impressed by this simple solution. Attenuation of higher freqs was about 40%.
    total cost £30...and that left enough mdf and butyl rubber to make four more shelves.
    zanash, Jul 20, 2006
  12. sastusbulbas
    smegger68
    Jun 30, 2006
    32
    How about a paving slab cut to size ? I've been thinking about doing this for the top shelf of my rack, for the turntable. Finish it off with some smoothrite, should look nice and be very inert.
    What do you guys think?
    smegger68, Jul 21, 2006
  13. sastusbulbas
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    I use 30mm thick granite. Heavy is good imo.
    I-S, Jul 21, 2006
  14. sastusbulbas
    Baudrillard
    Mar 7, 2005
    650
    Where do you get it from, if you don't mind me asking.
    Baudrillard, Jul 21, 2006
  15. sastusbulbas
    Jun 25, 2003
    4,842
    In a world of pain
    A place that makes granite worktops. The cut-outs from sinks and off-cuts are usually good sizes, and they will cut it for a modest fee. Some bits might even be free. I paid about £45 for the 4 shelves of my rack (which are different sizes, but they're ok.
    I-S, Jul 22, 2006
  16. sastusbulbas
    AlexTaylor
    Nov 13, 2005
    163
    I find heavy is bad as is glass.
    AlexTaylor, Jul 22, 2006
