Best Midrange?
Discussion in 'Hi-Fi and General Audio' started by Tenson, Jul 5, 2011.
What speaker has the best midrange?
  1. LS3/5A
    2 vote(s)
    8.7%
  2. ESL57
    9 vote(s)
    39.1%
  3. Tannoy DC
    2 vote(s)
    8.7%
  4. Bigger BBC Style Design - Please State
    1 vote(s)
    4.3%
  5. Other? Please state
    9 vote(s)
    39.1%
  1. Tenson
    Ken
    Jun 22, 2004
    208
    Perth - Australia
    Of the listed options I would vote for ESL57's.
    However I voted 'other', I think the Quad 2905 has the better mid range because it does not suffer the same constraints as the ESL 57.
    It has to be noted that Audio memory is fickle, and that the systems for 2905's is vastly different than the ESL 57's.
    Ken
    Ken, Jul 9, 2011
    #21
  2. Tenson
    RobHolt Moderator
    Oct 24, 2004
    Hi Ken,
    Anone used to hearing a 57 decades ago via valve amplifiers could be more than a little surprised hearing it driven by modern SS. The massive impedance swing from around 35 ohms in the bass to 1 Ohm at HF will very noticeably change the speaker response when driven by the low output impedance of (most) modern SS amps.
    RobHolt, Jul 9, 2011
    #22
  3. Tenson
    Tenson Moderator
    Nov 12, 2003
    5,947
    You mean when driven from high output impedance valve amps? ;)
    Tenson, Jul 9, 2011
    #23
  4. Tenson
    RobHolt Moderator
    Oct 24, 2004
    Yes, glad someone is awake :D
    #24
  5. Tenson
    Ken
    Jun 22, 2004
    208
    Perth - Australia
    Hi Rob,
    You are probably correct, that is why I cautined my response regarding my current system.
    I would like to hear a pair of 57's again with my present Pass Aleph Mono Blocks.
    Ken
    Ken, Jul 9, 2011
    #25
  6. Tenson
    Joe Petrik Denebian Slime Devil
    Jul 17, 2007
    121
    Rob,
    Were the 57s voiced with higher impedance amps in mind?
    When I had a pair I ran them with a Nait 2 and they sounded very good, but I sometimes wonder whether the 57s would have been better paired with a nice tube amp from the late 1950s, similar to how my old Tannoys sound much better with valve than SS electronics.
    Joe
    Joe Petrik, Jul 9, 2011
    #26
  7. Tenson
    RobHolt Moderator
    Oct 24, 2004
    Joe,
    Given PJWs record for having all bases covered, it is highly likely that the output impedance of the Quad II (current at the time) will have been accounted for.
    The quoted impedance of the II was around 1.2 Ohms IIRC and likely more at HF on the 16 Ohm tap.
    That will reduce HF output from the 57.
    Coincidentally, if you plot a 57 running from a modern SS amp it has a rising response on axis.
    Undoubtedly the two factors are complimentary.
    The Quad 303 does something similar but the effect is smaller.
    Interestingly, such is the 57 loading that even Naim amps will give a little roll down at the top.
    One thing audio sell a device called the 'Widget' which mimics this effect.
    #27
  8. Tenson
    felix part-time Horta
    Dec 13, 2003
    757
    dead
    Joe - IME - A Nait 2 works really darn well as a jack-of -all trades with the 57s.
    A fine valve amp (AudioInnovtions with Border Patrol PSU) definitely accentuated the ...desire to wear orange cardigans and only play Jazz recorded 1957-1959 on Verve or Riverside. Beautiful, if limited.
    With Serious Solid State, the 57s would play anything in a giggle-inducing manner (esp. the Aphex Twin. Ask JR.)
    I don't think that's real though - more a calculated effect. A drooping Z from the cap. loading certainly doesn't actually lift acoustic output significantly / ie I don't think ESLs sound bright driven like this... been a while, I could be wrong.
    Very good info on the interaction of 57s and the 303 here though:
    http://www.audiomisc.co.uk/57and303/interact.html
    felix, Jul 9, 2011
    #28
  9. Tenson
    RobHolt Moderator
    Oct 24, 2004
    Hi Martin,
    I think the 57 has rising treble driven from low source Z, two pairs have certainly measured that way and that is audible dead on axis. It happens fairly high and above the presence band so avoids sounding obviously bright and/or hard.
    I'm not saying a SS amp actually boosts top end, more that tubes amps reduce it.
    RobHolt, Jul 10, 2011
    #29
  10. Tenson
    Jul 17, 2007
    121
    Felix,
    I thought so, too, but a bit more weight at the bottom end would have been nice. In fact, that was the only reason I ended up with something else. With midrangy acoustic music the Nait 2/57 combination was very satisfying, but with rock, reggae and dance music it just wasn't working for me.
    I can think of worse places to be than stuck in the late 1950s.
    Yeah, would be interesting, but serious solid state usually has more than enough juice to arc the 57's panels.
    Joe
    P.S. NO ARC I.
    Joe Petrik, Jul 10, 2011
    #30
  11. Tenson
    Jul 17, 2007
    121
    Felix,
    I'd agree that some Tannoys — for example, the 15-inch HPD Berks I tried a couple of years ago — have an odd midband (a bit sucked out is how I'd describe it), but I don't feel that way about Monitor Reds in GRF cabinets.
    They're not quite at the zenith of 57 midrange magic, but the mids are very good and are what sold me on them thar old Tannoys. (If I had to fault the GRFs I'd say their top end isn't as extended as modern designs, but super tweeters can address that deficiency if you need a bit more tsssssst on your high-hats.)
    Joe
    #31
  12. Tenson
    jcbrum Black Bottom fan
    Mar 22, 2008
    222
    Brum
    Other : ADM9T
    Better than ESLs and DC Tannoys.
    A combination of modern transducers, built in pre, true active crossovers, good construction, and carefully matched powerful main amps (four of them in a stereo pair), - so no problems with amp matching or cable selection.
    JC
    jcbrum, Jul 10, 2011
    #32
  13. Tenson
    cooky1257
    Aug 30, 2007
    797
    Several large format compression drivers(on the right horn) are capable of astonishingly clear midrange.. JBL 2440, Vitavox S2, JBL 2435/476/Truextent Be's, TADs...
    cooky1257, Jul 10, 2011
    #33
  14. Tenson
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
    Yes, I use JBL 2482 for low mids and JBL 2435Be for upper mids.
    Very clear and detailed.
    S2's too expensive for me right now.
    speedy.steve, Jul 10, 2011
    #34
  15. Tenson
    Purite Audio Purite Audio
    Nov 25, 2006
    1,250
    TAD 4001 mid here, Supravox 11" field coil for upper bass.
    Keith.
    Purite Audio, Jul 10, 2011
    #35
  16. Tenson
    Mar 22, 2008
    222
    Brum
    Compression drivers on horns are a hangover from the '20's and '30's cinema auditorium era, when only low power amps were available.
    The high levels of distortion they produce are audible, but some who don't often listen to live music get to like the sound.
    JC
    #36
  17. Tenson
    Nov 25, 2006
    1,250
    There were a pair of AVI speakers playing at the Wigwam show this year.
    Perfect for the smallest room in the house.
    Keith.
    #37
  18. Tenson
    speedy.steve
    Dec 3, 2005
    525
    Can you tell us what well implemented hifi horn systems have you heard to base that comment upon?
    I do listen to live music quite a bit. Even small-medium sized venues were sound reinforcement is necessary usually use horn array systems.
    They often overdrive them and don't have bass horns for one reason - compactness.
    Good hifi horn systems are very different.
    #38
  19. Tenson
    Jul 17, 2007
    121
    #39
  20. Tenson
    speedy.steve
    Dec 3, 2005
    525
    #40
