Best speaker cable at £5/m
Discussion in 'Hi-Fi and General Audio' started by amazingtrade, Sep 22, 2003.
  1. amazingtrade
    5,139
    Manchester
    I am not happy with the sound from my system it makes through my speakers, I think it sounded better with FFRC (however my old ones are now to short and I haven't got the time to make new ones).
    My GALE XL315 -2 sound pretty lifeless though compared to how it used to do, the bass is also quite heavy and slow.
    I don't want to buy wire it so I am just looking for the best £5 speaker cable. Any ideas?
  2. amazingtrade
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    I have 2 x 5m runs of ffrc that i dont use anymore,
    If your interested you can have them for the postage cost
    let me know if your interested and ill double check them
    penance, Sep 22, 2003
  3. amazingtrade
    johnhunt recidivist
    975
    London
    my dealer swears nac5 is the best speaker cable for anything anytime. It's about 6 quid a m
    johnhunt, Sep 22, 2003
  4. amazingtrade
    PBirkett VTEC Addict
    2,456
    The Toon
    QED Silver Anniversary, hands down
    PBirkett, Sep 22, 2003
  5. amazingtrade
    cookiemonster
    1,316
    Berkshire
    I have 2x3m runs of FFRC i don't use anymore (they are off the I.Sibson production line in blue).
    cookiemonster, Sep 22, 2003
  6. amazingtrade
    johnhunt recidivist
    975
    London
    paul
    you might be right. I've used it but it was about three kit changes ago . I gave it to a friend who uses it for tethering a horse or something. I use nac 5 - as for a how good it is in reality I've never compared it to anything else. actually I could say the same about my whole set up although as each bit of kit has been added it did sound better. I suppose it was more money so it would. how it all compares to its peers I don't know. sounds OK to me though
    John
  7. amazingtrade
    zanash
    3,826
    Notts.
    you don't say how much you need !
    If your wanting off the peg cable well unless your going to spend a fortune,
    its horses for course.
    If you want different try getting a roll of 0.7mm enamell copper wire from maplin
    and try a few configurations . I've had good results from 4-6 twisted pairs
    not as bright as FFRC but better imaging and bass.
    But remember simpler is often better.
    My current experimental cable is working well, it's a simple 3m twisted pair of 1mm silver cores
    insulated with PTFE. This combo is so much more natural than the multi cores I've been using
    Swaping better cables shows that the multistranded copper is distortion the
    sound of some instraments and masking others.
    I'm not finding this to be any brighter than other cables I've tried......which is oddas silver is meant to be
    bright and clinical to the point of unbearaleness.
    Oh yes the copper wire is about £5 a roll and the silver 1mm cost less than £40 gosh that about £5.50/m
    zanash, Sep 22, 2003
  8. amazingtrade
    5,139
    Manchester
    Hiya thanks for all your input, I am thinking about the offers for the FFRC. I only need about 2 * 2 metre lengths at the most as my bedroom is so small, the silver aniversey also looks quite tempting.
    I will reply to this thread again when I've done some more research and sorted out a few other things.
  9. amazingtrade
    Phill77
    Aug 10, 2003
    74
    Zanash,
    Where do you get your silver wire from? Only stuff I have seen about is sterling silver, which I gather is only about 92% pure.
    Phill77, Sep 22, 2003
  10. amazingtrade
    Rory satisfied
    1,084
    Ipswich
    AT
    i am currently using £5/m Black Rhodium T90 on my £2500 Celestion Kingstons, and its holding up very well indeed, considering the price. Silver plated, solid core etc. When i get some Nordost or Isolda sorted i'll be open to offers. Its 4 5m lengths.
    Rory, Sep 22, 2003
