Beyerdynamic DT88O
Discussion in 'Classified Adverts' started by cookiemonster, Jan 3, 2004.
  1. cookiemonster
    cookiemonster
    1,316
    Berkshire
    [​IMG]
    'The DT880 is an ultimate headphone: an unique amalgam of the closed and open coupling technologies used in the DT770 and DT990 to create a semi-open headphone that can deliver the sensational low frequency energy within a semi-diffuse field to create a headphone response that so true that it is close to experiencing a live performance to wherever you happen to be listening. Described as “the best of both worlds†by leading magazines and reviewers the DT880 is constructed by hand in Germany from the very best transducer materials discovered by beyerdynamic research engineers – a no compromise headphone for use by true audiophiles. In fact the new DT880 is a rebirth – it was originally introduced in 1980 to wide acclaim: it was one of the first headphones to use lightweight diaphragm materials within high-power Neodymium magnet structures giving the DT880 unprecedented response characteristics. The new DT880 has all of these attributes plus many more features - integrating modern materials and technology to further enhance the characteristics and to improve the comfort over long listening periods. Supplied in an elegant aluminium box and complete with a special 5M extension lead the DT880 has no equal and is destined to become the premier headphone product in the world.'
    Technical Specifications
    Transducer type: Dynamic
    Operating principle: Semi-open
    Frequency response: 5 - 35,000 Hz
    Nominal impedance acc. to IEC 268: 250 &Mac189;
    Nominal SPL acc. to IEC 268: 96 dB
    T.H.D. acc. to IEC 268: < 0.2%
    Power handling capacity acc. to IEC 268: 100 mW
    Sound coupling to the ear: Circumaural
    Average pressure on ear acc. to IEC 268: 2.8 N
    Weight without cable: 270 g
    Cable length: 3 m / coiled cable
    I will also chuck in 2 extra extension cords in addition to the one included.
    Original receipt, paper work etc. Mint condition, very little use.
    The hinges on the aluminium box sustained slight damage in transit. Otherwise everything is A1.
    Yours for £80
  2. cookiemonster
    cookiemonster
    1,316
    Berkshire
    SOLD :)
