Hi guys, I'm having a look at getting a 3 channel and a 5 channel amp both in 9B ST chassis'. I want to bi-amp my IB1S mains and C6 centre. As there is no pass through on these I will have to split the signal somehow. I want to use balanced XLR connections and guess either splitting the cable will work or a proper XLR splitter. I was thinking though that it would be better to internally wire up the amps and therefore only need the one connection for each unit. I could also tri-amp the mains and bi the centre using the 3 channel for one and the 5 channel for one main and the centre. Any thoughts on this please? Any good engineers near Southampton that could do the wiring? The other possibility but more money is just get a 6B SST and forget the multi amping :rolleyes: Your thoughts and advice appreciated. Cheers, Bob
