blown 12au7?
Discussion in 'DIY Discussion' started by firestorm, Aug 19, 2005.
  1. firestorm
    firestorm
    Jul 1, 2003
    89
    London
    Inside the valve, the chrome bit has gone, replaced by a milky coating on the glass. I pulled the valve out and noticed there was a couple of cracks around the pins.
    Any one know what happened ?
    It is plugged in to my WAD KEL34 which I switched on for the 1st time last night. Guess something went wrong ;-)
  2. firestorm
    hifienthusiast
    Nov 3, 2003
    158
    Hampshire
    The glass of your valve has been cracked, perhaps when the amp was being moved or when the valve was pushed into the socket. The silver material (called getter) has been oxidised which turned white in colour. It can happen to any valve. If you want more detail how a valve work, read http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm
    Get yourself a new valve and hopefully your amp will sing again. Good luck.
    Hon
    hifienthusiast, Aug 19, 2005
  3. firestorm
    zanash
    3,826
    Notts.
    It's passed on to the great valve heap in the sky.
    zanash, Aug 19, 2005
  4. firestorm
    firestorm
    Jul 1, 2003
    89
    London
    thanks for that - the thing was only on about 5 minutes. As it was the first time I'd switched it on, I'm wondering if I had wired the thing up wrongly to cause this ?
  5. firestorm
    zanash
    3,826
    Notts.
    Ah now I see where your coming from........
    were the valves new or old ?
    do you have replacements ?
    is the amp new or old ?
  6. firestorm
    firestorm
    Jul 1, 2003
    89
    London
    hi zanash
    new ecc82 /12au7 made by EI, the amp needs a pair, one has blown up, so I'm on the look out for some replacements, something not too special/expensive, as I don't know if the amp works or not ! Its my 1st poweramp, I've made a couple of preamps already, they worked more or less straight away ... this one is giving me problems.
  7. firestorm
    zanash
    3,826
    Notts.
    causes ......could be the valve was damaged in transit ?
    triple check your schematics with your build .......you can never be too careful.
    try" hot rocks uk".............Ive had some superb sounding valves at good prices from these people.
    zanash, Aug 20, 2005
