Bought a new amp
Discussion in 'Hi-Fi and General Audio' started by lordsummit, Jul 2, 2003.
  1. lordsummit
    lordsummit moderate mod
    3,650
    In the Northern Wastelands
    Was idling around on Ebay last night when I saw a Linn Intek amp going cheap, got it for £160. Will give it a go if I don't like it am sure it will get it's money back.
    Anyone ever heard or heard of this amp, it looks quite new.
  2. lordsummit
    Mr_Sukebe
    912
    London
    One thing the intek is not is new. I believe that the unit in question is probably over a decade old, so don't make any assumptions about outright quality. On top of that, it was relatively cheap product at the time (I believe under £400), so it probably competed with the Audiolab 8000 and Cyrus 2.
    Mr_Sukebe, Jul 2, 2003
  3. lordsummit
    zanash
    3,826
    Notts.
    Ooops
    spoted this too
    Linn Intek AMPLIFIER SUPERB UNMARKED N/R £149.00
    Don't mean to wee on your strawberry's,
    Should be built like the proverbial outhouse, and should sound ok. A lot depends on what your used to.
    zanash, Jul 2, 2003
  4. lordsummit
    3,650
    No I'm not expecting miracles, I'm just intrigued as to how well it will compare to my Quad 33/303. If I don't like it I will sell it on again.
  5. lordsummit
    timpy Snake Oil free!!!
    441
    Cheltenham
    Indeed they did compete with the Audiolab 8000A etc, indeed the styling and functionality are very similar to the Audiolab, as was the price.
    I think they were launched in 1989-90 and the one I heard briefly was driving Linn Helix II driven by a Linn Axis and Marantx CD12.
    To be fair though I'm not very familiar with them at all really.
    Hope you like it.
    timpy, Jul 2, 2003
  6. lordsummit
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    I have one of these. I think it was built in 1990 and sold for £398. I used to like it very much until I heard a Rotel RA972 mkII for a back to back comparison a couple of years ago:( . Now it's connected to my PC at home but I still like it.
    Dev, Jul 2, 2003
  7. lordsummit
    3,650
    Yeah that's pretty much what I thought. Will hopefully be able to replace the Quads which are a little bit noisy and suffering from crosstalk. When the CD is on I can still hear the radio. Will give it a go. If I don't like it I'll sell it on like I said and probably get the Quads fixed. If nothing else it will fill a hole in my rack whilst they are being done.
  8. lordsummit
    441
    Cheltenham
    Hi Lordsummit
    Sounds like an earthing fault in the Quads. Have you tried whipping the plug-in cards out and cleaning the connections (observing all ncessary anti-static procedures obviously ;) ) ?
    timpy, Jul 2, 2003
  9. lordsummit
    3,650
    No not tried that. The main really annoying problem is that I have to remember to turn the tuner off before I listen to the CD, otherwise I can hear the tuner in the background. Same goes for any recording I make. Was planning on sending it to Quad for a service, but I believe that can take months. The Pre-amp is one of the very early units, 3000 and something, and whilst I love it to bits, it can be a little temperamental. If I can get it to work properly it will be back in my system I'm sure. The thing that attracted me to the Linn was that it should have a more than decent phono stage. A large percentage of what I listen to is on vinyl.
  10. lordsummit
    441
    Cheltenham
    I can't remember much specific about the Intek, apart from that fact that the bloke that had it said it was far far better than what he was used to (Nad 3220PE he'd had before). He'd upgraded his system in the way that sometimes happens, source, speakers and then the old "well it's just an amp routine".
    Changing from the Nad made sense of the Helix, which went from being dry, edgy and scrappy (which they are a bit anyway), so being fast and involving (but still a bit dry even for me). The Intek was a good amp definately, although a head to head with an Audiolab was never done. It was all esoterik ( ;) ) stuff to me at the time.
    As for the Quads, a service may well help that. As things get older the de-coupling caps can cause leak through of sound etc, where you don't want it (they are often used to stop it in the first place). Also with the plug in configuration it employs for some bits (all bits?) then this type of fault can often be attributed to poor small signal earthing, a deterioration which press fit connections encourage as they age. If the card earthing is suspect the de-coupling caps won't be being allowed to work properly even if they are ok. They rely on getting this "seepage" to earth if they can find it!
    I'm no Quad expert though, I'm sure Still Tones could shed more light on the construction, he's had his apart and replaced some cards with some after market "Go Faster" ones :D.
    timpy, Jul 3, 2003
  11. lordsummit
    Nepherim Deep Purple Flactulence
    131
    NJ, USA
    I used to own an Intek, and from my recollection, the build quality was very high. The only thing I'd check is the volume pot which was a split design for left and right channels. On mine they din't quite balance centrally. It had the kind of design that I suspect would not improve with age.
    It sounded pretty good. Up front, pretty quick and pace, neutral sounding. A pretty good amp from my memory, and better than AudioLabs I auditioned it with. Not better than the ExposureX though -- now that is an amp worth getting.
    ~ ~ Dave
    Nepherim, Jul 3, 2003
  12. lordsummit
    3,650
    Right it's arrived, it's certainly made an impression. It's generally a lot quicker and pacier than the Quads, but I don't think quite as easy to listen to. It made Tchaik. 5 very exciting, and some Haydn Quartets very involving. Don't want to go to far down the PRaT route but it certainly does have some of that. Am going to listen to it a bit and then try the Quads again. I think really it's a better amp, but maybe not as pipe and slippers. You should do a Smiley for that Cookie:cool:
    lordsummit, Jul 7, 2003
  13. lordsummit
    cookiemonster
    1,316
    Berkshire
    I'm a bit busy momentarily but the new PRaT smilie for now:
    :pRaT:
    ....and the not so good pipe and slippers (he's wearing some trust me):
    :Quad:
    (i don't think this deserves to stay long - offers for a better pipe and slippers on a postcard)
    cookiemonster, Jul 7, 2003
  14. lordsummit
    441
    Cheltenham
    Yep that's how remember it. The Audiolabs are a little smoother and a little more organic / traditionally balanced. Certainly the 8000A Mk2 is anyway.
    The Intek took a little bit of stick when it was launched, there were complaints about detail level and a general feeling in the press that the design wasn't all it might have been. Judged on it's own merits, it has a flavour that won't appeal to everyone, but IMO it is good to good+ as an amp. I've never lived with one though.
    Still, more importantly, you've got one to play with, and if you don't like it, you're unlikely to loose on it. And it is fun trying anyway, (says an epay addict that's just bought a Teac VDRS-T1....:rolleyes:) :D:D
    timpy, Jul 7, 2003
  15. lordsummit
    michaelab desafinado
    6,403
    Lisbon, Portugal
    Saw that - you jammy b*astard didn't have anyone bid against you :) Hope the same happens for the Teac tranny I'm currently bidding on...readers of this thread, if you find it, butt out, or I might have to make bidding against me a bannable forum offence :D
    michaelab, Jul 7, 2003
  16. lordsummit
    441
    Cheltenham
    Mine was "Buy It Now" :p. I almost hesitated, then I didn't. ;)
    Good luck with yours :D
    timpy, Jul 7, 2003
  17. lordsummit
    3,650
    Yup the Linn is staying for a while at least, then I might sell that and the Quads and buy that valve amp everyones talking about at the moment. Now that does sound like a good piece of kit. How hard is it to build? Bearing in mind I've never ever wielded a soldering iron:pRaT:
