Bowers and Wilkins CM8
Discussion in 'Hi-Fi and General Audio' started by Digbarnes, May 11, 2021.
  1. Digbarnes
    Digbarnes
    May 7, 2021
    6
    Are these speakers suitable for my Cyrus system?
  2. Digbarnes
    Sergeauckland
    May 31, 2012
    411
    84
    Suffolk
    I can't see any measurements on the CM8 regarding impedance as their nominal 8 ohm rating means nothing. It's the minimum impedance and at what frequency this happens that determines whether an amplifier will likely drive a loudspeaker properly.
    If your Cyrus amp is rated for 4 ohm loads, then I would expect it to drive the CM8 properly even if the impedance drops as I expect it would. If the amp is only rated at 8 ohms, then you'll need to find out what the CM8's minimum impedance is, and at what frequency.
    Sorry I can't be more precise, but in the absence of detailed impedance information, it would just be speculation, which I try not to do.
    EDIT - I've just read the spec on the Smartpower amp, and it is rated at 4 ohms, so would expect it to drive the CM8. It is also rated into 4 ohms in mono, so would expect it to do OK, but remember what I previously wrote about overheating in mono mode.
    S​
    Sergeauckland, May 11, 2021
