Broken NAD Power Amp !!!
Wanted: Discussion in 'Classified Adverts' started by greenphotos, Dec 6, 2004.
  1. greenphotos
    greenphotos Got any Broken NADs?
    Dec 6, 2004
    22
    Hampshire UK
    WTB: Trying to find a Broken NAD Power Amp !!!
    Hiya all, It's my first post so here goes!
    I'm trying to source a broken NAD power amp to put a PC inside and run my MP3 files etc through my existing NAD system. All I need is the casing, and I'll connect the NAD power button to the PC power button, add a Sound card + TV card, and hey presto! a cheap solution to a media server!
    So far, I have it all rigged up :D And it works GREAT! , but the PC looks V ugly where it is, and thus the Sasing is required to replace the current PC case.
    Only problem is, I can't find anyone with a broken NAD power amp for me to get the case from. It has to be the newer style ones - for example like this:
    [​IMG]
    I live in Hampshire, UK.
    Can someone help - pleeeeeeeese :(
    Great site BTW, have learnt lots, and everyone seems to be V friendly
    Mark
    :D
  2. greenphotos
    Joolsburger
    510
    phone nad they might sell you one
    Joolsburger, Apr 27, 2005
  3. greenphotos
    Dec 6, 2004
    22
    Hampshire UK
    I tried, they will sell me the front and the cover, but not the base. £50 for them both - not bad, but seeing as I'm just able to afford oetrol at the moment I think that'll be a 'when I can afford it' project...
    My TNT Flexitable on the other hand is finished and Superb! :)
    greenphotos, Apr 27, 2005
  4. greenphotos
    Paul Dimaline
    Jan 14, 2004
    135
    With a bit of lateral thinking I reckon you could make one for next to nothing. I got a non working Kenwood amp from a local Buy & Sell place a while ago and striped it down as I only wanted the case to house all my power supplies. I already had some 6mm alloy plate so I will cut that down to make a new faceplate. A metal merchant will probably charge no more than a tenner to cut a bit to size or you could even use MDF. A bit of effort with a file and emery cloth will soon have it to shape. A trip to the local Halfords to get a spay can of paint to match the NAD and away you go, job done.
    Paul Dimaline, Apr 27, 2005
  5. greenphotos
    rsand I can't feel my toes
    Feb 24, 2005
    903
    Liverpool
    Any pictures of your flexitable?
    rsand, Apr 27, 2005
  6. greenphotos
    Dec 6, 2004
    22
    Hampshire UK
    I'll get pics of the flexi-table up asap.
    About fabricating my own case, I really wanted the NAD one so it looked EXACTLY like a piece of NAD equipment... (Picky aren't I ;-)
