Budget AV Amp
Discussion in 'Hi-Fi and General Audio' started by andrew1810, Oct 18, 2004.
  1. andrew1810
    andrew1810
    Sep 20, 2003
    582
    Morpeth, Northumberland
    Looking at the poll, a few of you have AV setups so I need some advice from those of you.
    Am looking to upgrade my old Aiwa AV amp to one with some newer formats.
    I have about £180-£200 to spend and they will be paired with the stuff in my sig, a freeview box and a gamecube. Obviously music isn't needed.
    Options so far are:
    Pioneer VSXD714
    Pioneer VSXD811
    Denon AVR1705
    Harman Kardon AVR2550
    Anyone have any advice?
    Andrew
  2. andrew1810
    Rory satisfied
    1,084
    Ipswich
    none of them
    get something that has preouts andrew to link to your rotel
    Rory, Oct 18, 2004
  3. andrew1810
    andrew1810
    Sep 20, 2003
    582
    I had considered that but prefer to keep the two separate in case I have to move them about.
  4. andrew1810
    Rory satisfied
    1,084
    Ipswich
  5. andrew1810
    Rory satisfied
    1,084
    Ipswich
    surely its better that you can combine the two in the future? the better amps always have preouts anyway
    Rory, Oct 18, 2004
  6. andrew1810
    andrew1810
    Sep 20, 2003
    582
    Thanks, I will have a look at them.
    I noticed Lintone was selling one, might drop them an email
    Andrew
  7. andrew1810
    andrew1810
    Sep 20, 2003
    582
    Definitely, to keep my options open.
    I think all but the HK do have them but will double check
  8. andrew1810
    Rory satisfied
    1,084
    Ipswich
    the pioneer '714 doesn't.
    the pioneer '811 isn't a v.good amp. the 814 is though.
    i'd look at the yamaha 630 or marantz 7200 i linked to. if u can find either for under £200 they'd be a very good buy :) . They're 6.1 too.
    Rory, Oct 18, 2004
  9. andrew1810
    Rory satisfied
    1,084
    Ipswich
    the hk will sound good btw. i have the avr4500 but you pay an awful lot for the brand name. mine retailed at £650 but got it for £400 so wasn't too bad in the end
    Rory, Oct 18, 2004
  10. andrew1810
    andrew1810
    Sep 20, 2003
    582
    the HK is £220 new but that is a little over budget really.
    I like the look of the Denon and it has the newer formats which the HK is missing
  11. andrew1810
    andrew1810
    Sep 20, 2003
    582
    I've just seen the Marantz SR5400 for £200 which is very tempting and has everything I am looking for!!
    andrew1810, Oct 19, 2004
  12. andrew1810
    Rory satisfied
    1,084
    Ipswich
    even better if its the 5400ose andrew
    Rory, Oct 19, 2004
  13. andrew1810
    andrew1810
    Sep 20, 2003
    582
    I guessed it would be, but that is another £60 on top which is WAY over budget, I am pushing it as it is!!
  14. andrew1810
    Rory satisfied
    1,084
    Ipswich
    u know why= the 5500 is out now
    but no difference as far asi can see
    the 5400 has dplIIx
    Rory, Oct 19, 2004
  15. andrew1810
    ditton happy old soul
    Sep 18, 2003
    1,261
    Edinburgh
    hava look on AVTalk or AVForums for s/h avamps with pre-outs. The Denons above the AVRxxx2 models have PL2 and many have pre-outs. I have been a happy AVR2802 owner, though I've now upgraded to a meridian av processor.
    ditton, Oct 19, 2004
  16. andrew1810
    andrew1810
    Sep 20, 2003
    582
    I have seen an ex-demo Denon AVR1602 for £175, is this the next model down from the 1705?
    Have had a look on AVTalk and it all seems a bit slow! Will have a quick look on avforums but I don't remember anything recent
    Andrew
  17. andrew1810
    Sep 18, 2003
    1,261
    Edinburgh
    it doesn't have pre-outs. I used to own one.
  18. andrew1810
    andrew1810
    Sep 20, 2003
    582
    I have been offered a Denon 1603 or 3801 for within the budget
    Which is the better?
    Andrew
    andrew1810, Oct 20, 2004
    #18
  19. andrew1810
    Sep 18, 2003
    1,261
    Edinburgh
    I would not go for either.
    I doubt whether 1603 has pre-outs, and the 3801, although superior in so many ways, does not I think have DLP2.
    As it happens (and beware I may be about to sell you something) the best buy is a s/h 2802, as it has both pre-outs and DLP2. I bought one and have been happy owner, but as you can see from my sig. I only use it as stand-in as amplification while I source 3 channels of poweramp. I am looking to sell it on. PM me if you are interested.
    But I stand by a s/h 2802 or 2803 being worthwhile for your purposes.
    ditton, Oct 20, 2004
    #19
  20. andrew1810
    andrew1810
    Sep 20, 2003
    582
    You have PM
    #20
