Cable
Discussion in 'DIY Discussion' started by early, Dec 6, 2006.
  1. early
    early
    Nov 10, 2006
    82
    It's now time to turn my attention to mains cables , now these
    are going to be diy ( I can solder just as well as Mr Andrews et al )
    But where do I get decent cable by the metre ?
    Also which gives the best results shielded or litz type braid
    Thanks in advance , e .
    early, Dec 6, 2006
  2. early
    zanash
    3,826
    Notts.
    pm me ......
    I've a part spool, you can try a peice if you want
    its three core a 2.5mm csa and take 20amps
    zanash, Dec 7, 2006
  3. early
    Captain Beardy
    Dec 28, 2006
    3
    SW London
    Hello , Zanash,....
    What brand / type of cable have you found the best ?
    I'm about to buy a reel myself ,..
    Cheers,...... Dan.
    Captain Beardy, Dec 28, 2006
  4. early
    Toride
    Dec 13, 2005
    33
    SE London
    Toride, Dec 29, 2006
  5. early
    Captain Beardy
    Dec 28, 2006
    3
    SW London
    Just found a great looking DIY screened mains idea today,( decibel Dungeon was the site / link ).
    It uses two lengths of low loss coax cable with 1.25mm centre conductor,..
    One conductor is for neutral, the other is the live, and the braided copper screens of each length are joined / connected at the 13 amp socket end,..expanding outer sleeve is used to cover the two coaxs and regular 13 amp and IEC plugs can be used with a bit of modding to accomodate the OD of the cables,...
    ( Cable FT 125 in Maplin catalogue ,...99 pence per mtr ).
    I'm going to start gathering the gear tomorrow,.... should be interesting !
    Captain Beardy, Dec 30, 2006
  6. early
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
    Captain,
    That sounds just like the cables I made up over the Xmas break.
    One for amp one for CDP.
    I made them 2.0m long after Zanash mentioned length was important:)
    They were a great improvement on the normal cable and gave the kind of leap of sound improvement that I got when I borrowed a megabucks mains cable set made by Mr A.
    speedy.steve, Jan 2, 2007
