I have a small amount of low level hiss/crackle coming from my Cayin A88T . It's been suggested that there maybe dirty contacts causing the problem. I've checked inside and everything is fresh and bright, no signs of component problems. The valve sockets are showing no sign of corrosion, but I took an old valve to use as a cleaner, popped it in and out a few times with a lick of servisol contact cleaner on the pins (didn't want to be squirting anything into potentially charged sockets). Still have a bit of crackle though - any thoughts? Cheers people.
