Cambrige Audio Dacmagic in silver
Discussion in 'Classified Adverts' started by strider, Jul 20, 2009.
  1. strider
    strider panic now, avoid the rush
    Mar 3, 2009
    6
    Cambridge Audio Dacmagic in silver.
    I bought this last November and its in great condition. I have the stand, box and manual.
    This DAC needs no introduction to its capabilities. Inputs, it has 2 coax, 2 optical, 1 USB and a straight thru input/output. Outputs are single ended phono and XLR balanced. There are 3 filter options and you can reverse the phase if needed. it also outputs at 192kz...
    I will also chuck in a Maplins 12v PSU I bought and this did notch up an improvement in detail and bass weight and to my ears was worth the £15. I'll also throw in a Techlink 75ohm 70cm coaxial lead just for good measure. (worth a tenner)
    I paid £210 for it from Richer Sounds, I would like £185 including postage, I will include the original PSU as well.
    (these are £230 from Richer Sounds now!)
    Many thanks,
    Mark
  2. strider
    Mar 3, 2009
    6
    I will also be happy to do a direct swap with a Squeexebox (SB3) if i takes your fancy!
    strider, Jul 21, 2009
