Can you "crash" hifi?
Discussion in 'Hi-Fi and General Audio' started by robertz100, Feb 3, 2011.
  1. robertz100
    robertz100
    Jan 31, 2011
    16
    Please excuse my technical ignorance but I've always assumed you should put equipment to standby before flicking the switch at the wall but I'm not actually sure why..
    Two reasons why I bring this up,
    Firstly, my house-mate sat on the remote for the sockets once thus cutting the power to everything (they are inaccessible so I use radio-controlled plug socket), I heard a 'pop' as the power went, is this damaging to hifi?
    Secondly, the power switch on my subwoofer does not function correctly, it is either ON or in AUTO (goes to standby after 5 mins) but I can't manually switch it to standby straight away. Should I let it go to standby first before turning everything off, even with the amp off and no signal passing through?
    Thanks.
  2. robertz100
    RobHolt Moderator
    Oct 24, 2004
    9
    Some kit does have an intelligent stand-by and start-up sequence so i guess you could potentially crash these microprocessor driven systems.
    If it does happen, powering down completely at the wall socket and starting up normally should sort things.
    RobHolt, Feb 3, 2011
  3. robertz100
    Tenson Moderator
    Nov 12, 2003
    5,947
    The pop you hear is likely not to damage the equipment, but your speakers might not like it, if it is very loud.
    Tenson, Feb 3, 2011
  4. robertz100
    robertz100
    Jan 31, 2011
    16
    Just out of interest, what is it that would have caused the pop when the power was cut during playback? I assume it was something discharging?
  5. robertz100
    lAmBoY Lothario and Libertine
    1,233
    At home
    psu caps?
    lAmBoY, Feb 4, 2011
