Yes OK, I understand that everything is subjective but getting to hear a choice of carts is not what you could call easy. I have just changed my deck from a P25 to a P9 and would like suggestions for suitable moderate (?5-600) priced carts to use with it. It will have to work either with the MM stage built into a Cursa Pre amp, or the Rega phono MC stage, as I will not be able to replace the stage and cart at the same time. I will be using a DL110 in the short term. I would prefer something Neutral, or warmer sounding, (so not a OC9 or Dorian then) ________ [URL="http://bubblers.net/"]MARIJUANA BUBBLER[/URL]
