Well, much has been said of CD stoplight, and one thing that stuck in my mind was the claim that those who believe in it working have not presented any evidence to support their claim other than a claimed perception of improvement. So, how to test this using ( something that has become a catchphrase where I work) "a more scientific way of doing it"? Much of the debate has raged over the issue of bit errors. Stoplight doesn't affect bit errors as far as I know. A digital system such as making a digital copy of something (ie using a PC) should be unaffected by it. It's where real time conversion to analogue takes place that it has an effect, especially where the clocking is derived from the data of the CD. Thus, in order to measure the effect, a recording must be made from analogue, and compared with and without stoplight. So I did. I made two copies of a track from the original CD (ripped to .wav on hard disk, then written at 12x onto two Philips CD-R80 52X CD-Rs). One of these copies was then treated with stoplight on the outside edge and on the ridge near the spindle, the other was left without. These were then played without changing anything. A recording was made from the tape-out of the amplifier onto a PC. The recording format was .wav, and it was done at 24bits, 192kHz in order to provide a much higher theoretical resolution than any effects we might be looking for. Also, using a sample rate that is not a direct multiple of the CD 44.1kHz sampling rate means that timing errors (since this is via analogue, they can't be matched for start and stop time precisely) relative to the CD sample rate are similar for both recordings, rather than one having a greater offset than the other. So, onto some results... [img]http://www.askisaac.com/images/stoplight/stoplighttest1.gif[/img] The very beginning of the very first note of the track used (Starsailor - Tie up my hands). There are some subtle differences in the waveforms. Which is which is entirely inconsequential because we're looking for differences. Do little differences like those seen in the above image amount to much necessarily? Some analysis is needed... [img]http://www.askisaac.com/images/stoplight/stoplighttest_1.gif[/img] [img]http://www.askisaac.com/images/stoplight/stoplighttest_2.gif[/img] Now, that's fairly significant difference between the two.... Again, I have not said which is which. Discuss.
