hi guys, i know this is a bit off-topic, but i am confident that some of you can help... not long ago Michealab said something about choice of centre and surround speakers that made a lot of sense... :respect: basically that if looking for a 5ch musical setup one should ideally get all speakers from the same family/maker. However, if cinema is the main use for it, this is not so important, and some makes are more synergetic with eachother than others... i am looking to build a 5 channel setup and need to get a centre speaker and two surrounds. important point: it is just for movies, so i want to spend as little as possible (trying to be pragmatic... :rolleyes: ). the front speakers will be my beloved Sonus Faber Signum, driven by the MF A3.2. (i will use the preouts of the Denon 3802). does anyone recommend specific centre speakers or brands of speakers that will do well with the SFs? Any suggestions for surrounds? would something like mission work well at all? (apart from the picollo by SF i only know the triangle sextan202 is supposed to be good with them but it is very hard to find, and these are not that cheap...) as always, thank you very much for any help! :beer: Jack
