Cheap and cheerful DAB
Discussion in 'Hi-Fi and General Audio' started by zanash, Dec 21, 2005.
  1. zanash
    zanash
    3,826
    Notts.
    DA-1 DAB Audio Adaptor by Curry's.
    This is a small and cheap [£39]device that acts as a discrete DAB tuner, requiring a line level preamp to operate. So what do you get, the device, a remote, and a power supply. The Manuel is thin but gives the bare bones to be able to operate the device. Straight out the box, with no attention to aerial placement I was able to receive 5 stations, these sounded bubbly as if the announcer was speaking under water. Frankly I was going to take it back, but then I remembered how sensitive our other DAB is to aerial position. Carefully securing the cord aerial in as near vertical position as possible, I then rescanned for stations.This time the DA-1 found 29 local and national stations. The DA-1 has a seven segment signal strength meter, the centre position being the minimum required to provide an audio output, though in practice one segment less is listenable. Having now sufficient stations, the question was how to hold the aerial vertically. I've used a 5mm aluminium rod bent to form a base so it stands unaided. Initially the wire aerial was cellotaped to the rod, but this seemed to reduce sensitivity. The solution was to stand the aerial off the rod using short lengths of sticky tape. So how to improve the performance further ? Out went the cheap IC that I had used to get the unit going, and swapped with silver twisted pair this lifted performance several notches. Then I looked at the power supply, which is truly mediocre. This was swapped for a regulated adjustable lab power supply. Good grief is this the same DA-1 ? using the new psu signal strength is higher on average by one segment, and audio output is quality much improved. At some stage I'm going to open up the unit to allow a external aerial to be fitted and maybe access the digital output and route it to the DAC of my Quad 99cdp. So is this a cheap way into DAB, definitely but with the caveat that great care is taken with the aerial placement. Don't think that this is going to sound better than your troughline or fm3, but it will allow you access to those stations that only populate DAB.
  2. zanash
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    I might have a look at then, I only use the radio for footie and some games are DAB only (I cant believe Radio Lancashire sometimes actually broadcast dingle games instead of ours on the FM frequency, I might write to my MP about that). I do actually have two freeview things from my pre-sky days but these are ugly and require the TV for channel finding.
    T-bone Sanchez, Dec 21, 2005
  3. zanash
    Tenson Moderator
    Nov 12, 2003
    5,947
    I saw those... thought it was quite a nice toy :) Looks a bit like a squeeze box innit!
    Tenson, Dec 21, 2005
  4. zanash
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    What brand is it, cant find anything on their website.
  5. zanash
    zanash
    3,826
    Notts.
  6. zanash
    IndyAudi
    Sep 22, 2003
    66
    Miles from everywhere but very near perfect.
    IndyAudi, Dec 21, 2005
  7. zanash
    zanash
    3,826
    Notts.
    That and the links was exactly what I was looking for ! The soldering iron is now warming up .......
  8. zanash
    RSC
    Mar 29, 2005
    39
    I've had one of these for about a year now: not fettled it at all!
    It lives in my "study", with the PC and runs through an Exposure 7/8 with LS3/5a 'speakers.
    SQ is OK, but can't touch the main system's Roksan Caspian FM tuner (no surprise there, then!).
    As said elsewhere, useful for the non-FM stations and can't complain, not at that price!
    RSC, Dec 21, 2005
  9. zanash
    Will The Lucky One
    Feb 14, 2004
    552
    Halesowen
    Had my eye on this for a while, was hoping it'd have some form of digital output really :( (optimistic I know, but I have a spare input on my DAC, and the cheapo cambridge DAB tuners have both coaxial and optical outputs). Still, for the money, sounds an impressive enough bit of kit.
    Will, Dec 21, 2005
  10. zanash
    zanash
    3,826
    Notts.
    I've now added the coax connections......this has reduced the standard error rate from 15 to zero on my ten strongest stations. This has had a disproportionate effect on sound quality, jumping to a point where it is now close to fm via the cable TV feed. The aerial usd was a standard fm circular omni in the loft turned through 90 degrees ...not even orientated to the main transmitters. I'll add to the DIY section specfic details but they don't differ from those in the links provided.
    Its obvious that this source has its weeknesses but to get those stations that are not broadcast on fm.....this is a great cheap alternative.
    zanash, Dec 22, 2005
