Cheap set up (<£100)?
Discussion in 'Hi-Fi and General Audio' started by harrygrey382, Jan 7, 2007.
  1. harrygrey382
    harrygrey382
    Jun 16, 2006
    164
    Bristol/West Sussex
    Was telling my brother's girl friend she sould get a system that would flatten good computer speakers for under £100. Now I need to prove it...
    I was thinking something based round the likes of a Rotel RA921, NAD 3020 or CA A1.
    Now I'm a bit more stuck on the speakers. Kef, Mission, Mordaunt Short, Tannoy, assume I won't be able to include B&W due to price. But which models?
    She's a student so the room will be small and probably heavily furnished. She listens mainly to classical, but maybe a tiny bit of rock/pop.
    Can anyone help me here?
    Thanks
    Harry
  2. harrygrey382
    5,139
    Manchester
    Something like a second hand pair of Eltax Monitor IIIs may do the job, the only slight flaw with these is a slightly bright treble but the furnishings should help that, the bright treble will only be a problem if the source is bright anyway.
    You should pick up something like the 3020 or Cambridge A1 for around £30-£40 which leaves £60 to spend on speakers.
    Something like these may be ideal but I have never heared them.
    http://www.richersounds.co.uk/showproduct.php?cda=showproduct&pid=MISS-M2SS.
    I am pretty certain that system would make meat of any computer setup.
    amazingtrade, Jan 7, 2007
  3. harrygrey382
    dreftar
    Jan 3, 2006
    490
    Shetland Islands
    A pair of Edirol MA - 15 D These are excellent. They even have their own amp and DAC so you can connect them directly to a computers digital output. They also have connection for RCA type inputs and they have an out put to a sub woofer. - They as designed for nearfiels studio work and as such are ideal next to a computer monitor
    dreftar, Jan 7, 2007
  4. harrygrey382
    Tenson Moderator
    Nov 12, 2003
    5,947
    Tenson, Jan 7, 2007
  5. harrygrey382
    harrygrey382
    Jun 16, 2006
    164
    Bristol/West Sussex
    All good suggestions by the looks of it. Like the look of the Eltaxs' especially. At this price point, are active monitors better than a conventional passive/amp set up?
  6. harrygrey382
    Tenson Moderator
    Nov 12, 2003
    5,947
    IMO, vastly.
    Tenson, Jan 7, 2007
  7. harrygrey382
    Goomer
    Sep 1, 2003
    598
    I was putting together a bedroom system - the room is about 10' square - a little while ago and set the budget of £100.00.
    I managed to get a Creek 4040 amp (£5.00, free ads), a Technics SL-PG477A cd player(£10.00, car boot sale), Arcam T21 tuner(£15.00 Free ads), and a pair of JPW ML-510i speakers (£30.00 inc postage from ebay). I decided to go crazy with the rest and blow £10.00 on some T+E mains cable for the speaker cable and use the freebie phono plugs to hook it up with.
    It was accumulated over a period of 6 weeks, and sounds fantastic for the money - it can be done, I think you just have to be patient and a little bit lucky.
    Goomer, Jan 7, 2007
  8. harrygrey382
    maddog 2
    Jul 16, 2003
    319
    I use some MS20i speakers and a Marantz A400X amp in the kitchen and they sound good. Speakers were £25ish and the amp £40ish IIRC
    Currently runs off the main system via a long interconnect but will soon be squeezeboxed onto a 300gig harddrive
    maddog 2, Jan 8, 2007
  9. harrygrey382
    Snoo
    Sep 8, 2003
    240
    Bristol
    Building cheap set ups is possibly more fun than assembling a main system IMO.
    Snoo, Jan 8, 2007
  10. harrygrey382
    5,139
    Manchester
    Indeed :) You also don't get rather annoying feeling when you realise you're bank account is £100's or even £1000s down either.
    amazingtrade, Jan 8, 2007
  11. harrygrey382
    Snoo
    Sep 8, 2003
    240
    Bristol
    You are also a lot more comfortable diving inside with a ham fist and a soldering iron! :D
    Snoo, Jan 8, 2007
  12. harrygrey382
    spev
    Jun 13, 2005
    88
    I can heartily recommend a NAD3130 (superior to 3020 apparently) and a pair of celestion 5 speakers - kept me going for years and always got +ve comments from people coming through the various flats the system lived in. Should be able to pick up both for under £80. 3020 amps seem to be going for silly money on ebay at the moment...
    spev, Jan 8, 2007
  13. harrygrey382
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
    I've got my 26 year old NAD3020 and Mission 700's, a quality Yamaha tuner (bought for £5) and an early 90's Technics CDP in the garage - For a garage system it rocks!
    The CDP did need a tweak of the laser and focus pots some 15 years ago and has been good as gold since.
    That lot can't be worth so much can it?
    speedy.steve, Jan 8, 2007
  14. harrygrey382
    6,766
    bucks
    harry,
    I don't think you will better some active reveals for £100.
    Thats the best deal I think thats been discussed here.
    bottleneck, Jan 8, 2007
  15. harrygrey382
    ShinOBIWAN
    Jun 7, 2006
    710
    I'm with Simon on the actives. It would be a big ask to beat those Tannoys at a mere £100.
    ShinOBIWAN, Jan 8, 2007
  16. harrygrey382
    harrygrey382
    Jun 16, 2006
    164
    Bristol/West Sussex
    OK guys, I'll take your waord and press for active Tannoys
    harrygrey382, Jan 8, 2007
  17. harrygrey382
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    If you are going for the ones that Tenson linked to I'll stop bidding. It's not like I need yet another pair of Tannoys:D.
    Dev, Jan 9, 2007
  18. harrygrey382
    harrygrey382
    Jun 16, 2006
    164
    Bristol/West Sussex
    I'm not bidding yet Dev, she needs to give me the go ahead. So bid away. Thanks for the offer though
    harrygrey382, Jan 9, 2007
    #18
  19. harrygrey382
    stevehi-fi stevehi-fi
    Oct 22, 2006
    39
    west yorkshire
    high-fi on a low-fi budget
    Have you considered Marantz/Tannoy amp/speakers. In the 90's Marantz amps were "tuned" to partner Tannoy speakers, or it may have been vice-versa. Either way, the synergistic effect was very successful, and the combination was bought by many - including lots of students purchasing from Richer Sounds.:)
    stevehi-fi, Jan 10, 2007
    #19
  20. harrygrey382
    hifi addict
    Sep 26, 2006
    505
    Hastings
    hifi addict, Jan 10, 2007
    #20
