Cyrus pre x and mono blocs
Discussion in 'Hi-Fi and General Audio' started by rtg0616, Nov 1, 2006.
  1. rtg0616
    rtg0616
    Nov 1, 2006
    Hi guys, I'm new to the forum and was wondering whether anyone here is using the above amp setup. Or even better, is anyone using 4 mono blocs? I'm thinking of purchasing and would appreciate any feedback (no pun intended)
    Cheers,
    Roy.
  2. rtg0616
    Sgt Rock
    873
    Sgt Rock, Nov 1, 2006
  3. rtg0616
    indolent
    Dec 28, 2005
    105
    the cyrus unofficial guys are very helpful. Give them a shout.
    Dont forget to look at alternatives if you want to run 4 mono-xes tho. Wadia Meister (here) sells the Bel Canto E.Ones and they are the same size and pretty fab.
    indolent, Nov 1, 2006
  4. rtg0616
    Tenson Moderator
    Nov 12, 2003
    5,947
    Don't BelCanto also make a 4 channel amp that could be used for bi-amping?
    Perhaps also consider Flying Mole and even the Bryston power-pack series that can sit behind, or even on the back of, your speakers.
    Tenson, Nov 1, 2006
