I changed my cd player the other day to my friends Roksan Caspian (which I should be buying). Everything was fine until, yesterday my system started making a humming noise. I worked out that it was my dac causing the noise. I bought the dac (deltec/dpa bigger bit + RF mains cleaner) over e bay (to replace my little bit dac) about 3 months ago & had been using it with my NAD C521BEE cd player & although it worked, I had encountered a few problems: It gave off minor electric shocks on some occasions!:yikes: My system made a loud fuzzy noise whenever I loaded up a cd. I did e mail the seller after experiencing these problems & he advised me that it might be an earthing problem & that I should probably stop using the dac until I fixed the problem. He also informed me that he had'nt experienced any of these problems. I ignored the advice & continued to use the dac thinking it still did the job & I did'nt want to have to stop using it having only just bought it! (I know this was probably quite stupid). Im now having to make do with the little bit dac again...:( Does anyone know what problem I might have with my dac & whether it will be worthwhile trying to get it fixed? (or should I just look for a new dac?):confused: .
