My Totem Arros use some sort of Nasa inspired borosilicate paint to damp the internal walls of the boxes. For my current WD20 project does anyone know of a comercially available equivalent I might use or should I use damping pads or what. I seem to remember having read that some of you are anti-damping pads (Tenson ?) but is this just a gut reaction or does it depend on the size/materials of the panels ? In my case the boxes are braced and the panels to damp between braces would be say 20cm x 20cm of 16mm chipboard skinned with 5mm mdf. What difference could be expected between damped and non-damped panels of these dimensions ?
