Damping Material
Discussion in 'Hi-Fi and General Audio' started by osama, Sep 8, 2003.
  1. osama
    osama Perenially Bored
    Jun 28, 2003
    178
    in a very hot place
    Aside from the specialized damping materials produced only for hi-fis, what could possibly be some cheaper alternatives? I was thinking of the Vileda window cloth as it describes the product to have high content of natural fibres and is highly absorbent of liquid. I wonder if this would absorb heat and vibrations as well :confused:
    regards
    osama, Sep 8, 2003
  2. osama
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    blue-tak;)
    penance, Sep 8, 2003
  3. osama
    Jun 28, 2003
    178
    in a very hot place
    hi penance. Are you suggesting that i cover the casing of my kits with lots of this?:confused:
    regards
    osama, Sep 8, 2003
  4. osama
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    the stuff to soundproof cars might be a good alternative...
    rob, Sep 8, 2003
  5. osama
    Jun 28, 2003
    178
    in a very hot place
    Any particular description of the stuff, brand name?
    thanks
    regards
    osama, Sep 8, 2003
  6. osama
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    havent got a clue. most classic car mags will have adverts.i dunno if it will work or not as ive never tried it. blue tac sounds interesting though...
    rob, Sep 8, 2003
  7. osama
    Jun 28, 2003
    178
    in a very hot place
    thanks rob. will go tonight to car shops and ask about this.
    hope this works.
    regards
    osama, Sep 8, 2003
  8. osama
    Jun 30, 2003
    6,004
    yea you could cover it, not practical tho.
    as AT said, the auto damping sheets, tho the ones i have seen have bitchumen in them and i doubt you want that near a source of heat.
    Cork tiles is a possibility, or copper sheet - tho that defeats the idea of cheap
  9. osama
    Jun 28, 2003
    178
    in a very hot place
    Auto Damping materials with flammable properties is indeed dangerous. My Quad 306 is a class A amp that gets hot like an oven. If that's the case with auto materials then out this go from my list.
    regards
    osama, Sep 8, 2003
  10. osama
    HenryT
    1,288
    Devon, UK
    Dynamat. :)
    HenryT, Sep 8, 2003
  11. osama
    Jun 28, 2003
    178
    in a very hot place
    Hi Henry. No flammable properties?
    regards
    osama, Sep 8, 2003
  12. osama
    Chea Johndle Bizarre Serpent Foomaster
    217
    Foo Central
    Errrrrr????
    Class A/B and it should not get too hot....
    Regards
    Chea Johndle, Sep 8, 2003
  13. osama
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    if you use this stuff to sound proof the engine bay of a car i would have thought it was flame retardent..still not so sure it would work for dampening hi fi though.
    rob, Sep 8, 2003
  14. osama
    Jun 28, 2003
    178
    in a very hot place
    Corrections? I thought I read its spec as a class A amp :confused: But it does get hot more than the normal.
    regards
    osama, Sep 8, 2003
  15. osama
    zanash
    3,826
    Notts.
    I've been trying some foamed butyl rubber, has the same feel as sorbthane, but not quite the same properties. It works well as damping and as a composite in a stiff light shelf or base for CDP.
    I used 6mm MDF top and bottom to make a sandwich with the FBR.
    Its a dense foam 70kg/m3 15mm thick
    You can get a roll of the stuff from Decathalon
    http://www.decathlon.co.uk/ukstore/...4908&mscssid=Q4BQRM1K4QUU9PEKNSUSSQH3V4LA4MR1
    zanash, Sep 8, 2003
  16. osama
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    ive spiked some of my units and put them onto mdf panels with feet in an attempt to drain unwanted vibs.im gonna put inner tubes under the mdf in order to stop unwanted groundborn vibs.
    could be barking up the wrong tree though.
    rob, Sep 8, 2003
  17. osama
    7_V I want a Linn - in a DB9
    Aug 7, 2003
    2,013
    Great Missenden, Bucks
    What are you trying to damp?
    7_V, Sep 8, 2003
  18. osama
    Ashamed
    Sep 8, 2003
    6
    i like blu tack:D
    Ashamed, Sep 8, 2003
    #18
  19. osama
    Lt Cdr Data om
    Jun 24, 2003
    1,752
    what about stuff for lining speaker walls....anybody know what else works...anybody tried the brown bread from craplin??..is that for damping walls or absorbtion of sound..?
    Lt Cdr Data, Sep 11, 2003
    #19
  20. osama
    robs
    Jun 24, 2003
    277
    Interesting article on damping here - even a little bit of theory!
    http://wwwu.earsc.com/engineering/vibration/isolation.phtml
    I actually 'obtained' some isodamp rubber sheet to line my CDP. Seems to work very well - as it should! I think it is extraordinarily expensive, but I'll see what I can find out.
    robs, Sep 11, 2003
    #20
