Dedshete
Discussion in 'DIY Discussion' started by Graham C, Nov 23, 2003.
  1. Graham C
    Graham C
    680
    Leicestershire
    Anyone have any cheap sources for dedshete
    [panel deadening goo] as my previous source has stopped?
    I needed a box of pads or equivalent, for 2 x 100 litre
    cabinets. Im hoping maybe Steve 7-V Margolis might have a clue..
    I'm currently experimenting with clear type hot melt glue as
    a [sort of] alternative. [5kg for £20 from axminster]
    cheers for any ideas,
    Graham C
  2. Graham C
    zanash
    3,826
    Notts.
    zanash, Nov 27, 2003
  3. Graham C
    Graham C
    680
    Leicestershire
    Cheers mate, I just think Wimslow are too pricey. I appreciate its not a high turnover business, DIY speakers. Wimslow are twice the price that Falcon used to charge. I could go to the car-boys as well, but their stuff costs even more of a fortune
    ie for 2 x 100 litre cabs deshete at Wimslow prices thats about £45 by the time you add 2+ layers which I need cos the cabs are 18mm ply..
    Graham C, Nov 27, 2003
  4. Graham C
    ericallan
    Aug 29, 2003
    3
    Yorkshire
    Have falcon stopped supplying these? - the website says the type 2 ones are stuck together at the bottom of a one ton pile but the others seem to be there.
    ericallan, Dec 1, 2003
  5. Graham C
    Graham C
    680
    Leicestershire
    Yeah, I had a delivery from Falcon this week, and they wouldnt/couldnt supply either type
    Wilmslow is 1/2 the size per pad [300 x 200]@1.30
    I bought their 10mm foam covered pads at 1.50 each, but I'll be interested to see if 1 layer is thick enough..
    Graham C, Dec 1, 2003
  6. Graham C
    ericallan
    Aug 29, 2003
    3
    Yorkshire
    Wilmslow stuff
    Let me know if its any good - I'm going to need some soon for a project.
    Thanks
    ericallan, Dec 2, 2003
  7. Graham C
    michaelab desafinado
    6,403
    Lisbon, Portugal
    What is this stuff?? I can just imagine walking into a shop and asking for "dead shit" :D
    michaelab, Dec 2, 2003
  8. Graham C
    Graham C
    680
    Leicestershire
    This will tell you more than you could possibly want to read. It's as dry as any reference can get:
    pdf download of BBC research
    Table 4 on p18 has results of 21 sticky things to put on your speaker cab walls. The BBC have always been partial to thinnish walls coated in lossy substances, rather than very thick panels.
    Dedshete [10 on table 4] is self-adhesive fabric in pitch [I think], Like a self adhesive cookie, but not as tasty. Used by lots of respectable speaker companies at one time. Dried shit would probably also work quite well I imagine
    cheers,
    Graham C
    Graham C, Dec 2, 2003
