Does anybody know anything about IIS server or Windows permisions?
Discussion in 'General Chat' started by amazingtrade, Apr 13, 2005.
  1. amazingtrade
    5,139
    Manchester
    I am having permision problems on my IIS server. It cannot open an Access database. When I check the permisions of the wwwroot folder it says read only, which is clearly wrong since I can write to that folder.
    When I click of read only and give the folder full permisions and then check the property again it still says read only.
    I am not sure what is going on, does anybody know how to solve this problem? I really don't want to have to format it.
    Thanks.
  2. amazingtrade
    5,139
    Manchester
    I think I have sorted the permision problems now (I hope) I have just messed up Visual Studio instead :(
  3. amazingtrade
    GTM Resistance IS Futile !
    389
    UK
    Are you sure your IIS is logged in as a user that has full permissions ? I know that sometimes applications can be installed under different user types so maybe this is the problem. Just a shot in the dark, as I've never experienced this myself.
    GTM
    GTM, Apr 15, 2005
  4. amazingtrade
    ats
    Mar 15, 2005
    40
    south west
    Perhaps you need to tweak the flux capacitor.
    ats, Apr 15, 2005
  5. amazingtrade
    5,139
    Manchester
    I sorted it out in the end, the problem was that simple folders was turned on which I meant I could not change the permisions. I changed the permisions to the access file and it works fine now.
    Thanks.
    amazingtrade, Apr 15, 2005
