Dynamic Turtle needs a new phono stage - Budget up to £1500
Discussion in 'Hi-Fi and General Audio' started by Dynamic Turtle, Apr 20, 2006.
  1. Dynamic Turtle
    Sep 28, 2004
    1,469
    Planet Dirt, somewhere on it
    It boils down to practically completely disassemble the Dajngo and re-build, except the wiring from input jacks to the Input selector switch.
    Never had a chance to directly compare. Reading between the lines and based upon our experiences in upping the iron content in S&B Transformers I would suspect that they fall into a direction closer to the AM transformers.
    Basically, AM (unless it is in effect AM Permalloy) is still just generic iron, except it has no crystal structure.
    But the BH Curve (which describes how the core gets magnetised by the applied signal and then applies the signal back to the secondary and which can be taken as transfer curve, similar to that in amplifiers) for AM Iron is still that for iron and not that for nickel/iron alloy (aka superpermalloy, mumetal, Ni/Fe 80/20). And the BH curve for Iron is a lot less linear than that for Ni/Fe 80/20.
    As said, I do not have a Cole at hand, my own Phonostage shares a lot of the Principles but is also in crucial areas different. A Pentode connected E810F loaded into 600 Ohm does different from a Hybrid Mu-Follower using an ECC88.
    Ciao T
    3DSonics, Apr 21, 2006
    #21
  2. Dynamic Turtle
    anon_bb Honey Badger
    May 30, 2005
    2,804
    Thanks! Thats close enough to satisfy my curiosity if it uses the S&B stepup and riaa modules. I am just interested in hearing that approach whether in the cole or not. No rush obviously - I know you are very busy ;)
    I assume you are talking about hysteresis and non-linearity effects like the transfer function. It does seem the AM core is adding something so I look forward to getting the S&B for comparison. I have also ordered a stepup to try with the borbely which wil be switcheable mc/mm. If that works well then I will borrow or buy a silver stepup to compare with the copper before deciding to put silver into the Django.
    Can a soldering klutz like myself do it easily enough or do I need to find an electrician?
    anon_bb, Apr 21, 2006
    #22
  3. Dynamic Turtle
    Tenson Moderator
    Nov 12, 2003
    5,947
    Nick, if you look in the book I gave you with the Django you will find detailed instructions on how to install the transformers.
    Tenson, Apr 21, 2006
    #23
  4. Dynamic Turtle
    May 30, 2005
    2,804
    Ah ok I will take a look!
    #24
  5. Dynamic Turtle
    Feb 23, 2005
    935
    Hang on a minute - is the S&B TX option is purely used as a step-up for MC carts? If so, that may not be necessary, as the Dyna outputs 2.8mV.
    DT
    Dynamic Turtle, Apr 21, 2006
    #25
  6. Dynamic Turtle
    6,766
    bucks
    What puts me off the stage DT is that there is realistically no way to hear one before you buy (as it is a kit, and an american one at that), that it would be difficult to sell on being a relatively unknown brand, and that if you did so you'd only get 1/2 your money back.
    I would love to hear one though.
    bottleneck, Apr 21, 2006
    #26
  7. Dynamic Turtle
    Sep 28, 2004
    1,469
    Yes.
    Indeed, it will be fine then without any stepup transformer.
    Ciao T
    #27
  8. Dynamic Turtle
    Sep 28, 2004
    1,469
    It is not american, but HK.
    In terms of performance I'd expect you need to go up to and maybe past stuff like the Lamm LP2, Aesthetix Io and the Wavac.
    Ciao T
    #28
  9. Dynamic Turtle
    May 30, 2005
    2,804
    Me too! How can I do it?
    #29
  10. Dynamic Turtle
    6,766
    bucks
    we can't rely on opinion on these things though, and thats the problem.. we have to have demo's in our own kit in our own room.
    For example T, you said that the transformer based pre-amp I tried was considerably better than my consonance basie pre, but in the context of my system/room it was demonstrably worse to my ears and the ears of other people in the room.
    With a kit, you just can't have the demo you need... unless you chance across someone who already has one.
    #30
  11. Dynamic Turtle
    May 30, 2005
    2,804
    Or maybe it just opened the window wider on a problem elsewhere - its like peeling an onion.
    #31
  12. Dynamic Turtle
    Sep 28, 2004
    1,469
    Absolutely. That would something that would need to be discussed with Brian Cherry, it's his business... ;) What I do know is that the S&B LCR RIAA Modules are in perpetual short supply (just as the other "reference grade" S&B Products), so you may find that Brian would be able to offer options to allow a return if not suitable and not marked etc...
    But as said, that is not my area.
    Ciao T
    #32
  13. Dynamic Turtle
    6,766
    bucks
    thats always possible. Equally possible of course that in your own system the transformer passive ''closed'' the window on a problem elsewhere.
    both idea's are a hiding to nothing - a home dem is always the answer.
    #33
  14. Dynamic Turtle
    May 30, 2005
    2,804
    Indeed - yes when in the passive tvc everything got unequivocably much better. But the AM core still has colourations - hence trying the S&B core next.
    There is no foolproof method for persuing improvement unfortunately - I think we will both admit that :(
    #34
  15. Dynamic Turtle
    huuge
    Mar 16, 2005
    48
    see my classified
    much loved delphini 2 nc for sale
    huuge, Apr 21, 2006
    #35
  16. Dynamic Turtle
    Jul 28, 2003
    1,028
    The Marches
    Don't forget the Brinkmann Fein...
    And you can home demm it from Walrus..
    leonard smalls, Apr 22, 2006
    #36
  17. Dynamic Turtle
    May 30, 2005
    2,804
    I have owned the brinkmann fein - if you are single source its a great idea as it has a buffered volume control so you can run it straight into a power amp and its great value for money. Otherwise there are better choices. Brinkmann is bringing out a new higher performance unit though.
    anon_bb, Apr 22, 2006
    #37
  18. Dynamic Turtle
    Markus S Trade
    1,527
    Nether Addlethorpe
    How about a group buy of an S&B'ed Cole? If, say, three people chip in to try one, the loss on reselling if it turns out to be no good would be bearable. I'd be willing to join in.
    Markus S, Apr 22, 2006
    #38
  19. Dynamic Turtle
    6,766
    bucks
    not me sorry.
    I only buy equipment I can sell on for similar amounts of money, and try not to buy blind.
    bottleneck, Apr 22, 2006
    #39
  20. Dynamic Turtle
    Tenson Moderator
    Nov 12, 2003
    5,947
    Out of three, the chances are one of you will want it though...
    Tenson, Apr 22, 2006
    #40
