Eichmann Bullet Plugs...
Discussion in 'Hi-Fi and General Audio' started by davidcotton, Jul 7, 2003.
  1. davidcotton
    davidcotton prog rocker, proud of it!
    Jun 22, 2003
    182
    Dorset
    Well I've got a pair of Kimber pbj ics lying around with just some cack nickel plugs on (hey at the time I was a bit skint so thought I'd save some cash). Is it worth getting them (or any other ics that I have) reterminated with Eichmann bullet plugs? Is there a noticeable difference or is it "snake oil" again? Or would I be better off spending the money on some more obscure cds:p ?
    Cheers....
  2. davidcotton
    Robbo
    2,371
    Berkshire, UK
    in my experience, yes it is worth it if you are only using crappy plugs. But they are not too easy to solder and it is easy to overheat them and partially melt the plastic:eek: so be careful of you do it.
    cheers, Robbo
    Robbo, Jul 7, 2003
  3. davidcotton
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    Robbo is right, in that they're a pain to solder. I have them on my ICs. Use silver solder if you're going to bullets.
    I-S, Jul 7, 2003
  4. davidcotton
    6,026
    Beyond the 4th Dimension
    Spend the time, and build a jig first (a female rca end from maplins £2, in a piece of wood will do), saves plugs and burnt fingers, use a free flow solder smaller diameter,(just use more of it), these terminations, are a big step up in preformance, over even top quality RCA's, and are worth considering if you can't afford to upgrade the cable. WM
    wadia-miester, Jul 7, 2003
  5. davidcotton
    robert_cyrus
    685
    near the sea
    my soldering is not the best, and i managed to reterminate the nuvistas without too much hassle. just be careful with the bullets, there's a little bit of plastic that keeps the ground pin in place that kept coming loose, falling on the floor, and temporarily disappearing.
    i think the best price is at http://www.hificables.co.uk/
    robert_cyrus, Jul 8, 2003
  6. davidcotton
    Chea Johndle Bizarre Serpent Foomaster
    217
    Foo Central
    A BIG gob of Blu-Tak :D :D is a good "Jig" to hold things steady whilst handling the hot rod....
    Put some a few cm away to hold the wire steady as well....
    Regards
    Chea Johndle, Jul 8, 2003
  7. davidcotton
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    What a simple and excellent idea:eek:
    Dev, Jul 8, 2003
  8. davidcotton
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    Blue Tak is the solderers friend :D
    penance, Jul 8, 2003
  9. davidcotton
    zanash
    3,826
    Notts.
    Have you never seen molten Blutac.......it gets everywhere. More than a pea sized blob and I run for cover !
    Wm's right build a jig take just a few minutes. you could solder some solid core to the sockets pins and make a heat sink by bending it back and forth concertina fashion.
    zanash, Jul 8, 2003
  10. davidcotton
    MO! MOnkey`ead!
    4,881
    anyone compared the standard bullets to the silver ones? seems like a lorra lorra MOney!
    MO!, Jul 8, 2003
  11. davidcotton
    Mat Bon 0013 Going nowhere fast
    37
    Big Blue Marble
    Indeed and common sense plus patience :MILD:
    Mat Bon 0013, Jul 8, 2003
  12. davidcotton
    6,026
    Oh yes MO, but MOney well spent, if the equipment warrents it :)
    wadia-miester, Jul 8, 2003
  13. davidcotton
    murphybridget
    Nov 30, 2023
    59
    13
    Ah, molten Blu Tack—a force to be reckoned with! It's like the ultimate sticky chaos, isn't it? Building a jig definitely sounds like a wise move to contain the molten mayhem.
    murphybridget, Feb 8, 2024
  14. davidcotton
    murphybridget
    Nov 30, 2023
    59
    13
    Using a jig and soldering solid core to the socket pins sounds like a practical approach for managing heat dispersion during soldering. Heat sinks can be incredibly helpful in preventing damage to delicate components.
    murphybridget, Feb 12, 2024
  15. davidcotton
    Arkless Electronics
    Sep 7, 2016
    148
    69
    Or just use normal easy to solder phonos for a few pennies. They all sound the same obviously.
    Arkless Electronics, Feb 12, 2024
  16. davidcotton
    murphybridget
    Nov 30, 2023
    59
    13
    Using easy to solder phonos sounds very cost effective. In my case, as a preventive measure I always use alligator clips not only to hold workpieces together but also to serve as heat sinks.
    murphybridget, Feb 14, 2024
  17. davidcotton
    murphybridget
    Nov 30, 2023
    59
    13
    How about flux? Do you favor anything in particular?
    murphybridget, Feb 28, 2024
  18. davidcotton
    Arkless Electronics
    Sep 7, 2016
    148
    69
    Flux is not required in normal electronic soldering as the solder itself contains a flux core.
    Arkless Electronics, Feb 28, 2024
    #18
