emu 0404 question
Discussion in 'Hi-Fi and General Audio' started by samurai, Jan 20, 2007.
  1. samurai
    samurai
    May 17, 2004
    35
    If I have a emu 0404 connected to a amplifier, would there be another possibility to listen to pc speakers (so you would not need to turn the amp on with webcam for instance)? There is a audio connection in front of the pc via a audio header on the motherboard, but I guess it will not work with the onboard soundchip turned off?
    thanks,
    Gert
    ________
    no2 vaporizer review
  2. samurai
    ansis
    Sep 8, 2005
    5
    you can use both built-in and pci soundcards simultaneously if you have half decent motherboard, just specify in player output which one you want, i have used 3 cards without any problems (built-in, usb and pci)
    ansis, Jan 21, 2007
  3. samurai
    samurai
    May 17, 2004
    35
    samurai, Jan 22, 2007
