English Valve amplifiers, anounce the first in a line of Valve based audio equipment. Starting off with: Proteus 20w Valve intergrated amplifier. Stainless Steel Chasis using KT88 power valves. 20 Watts RMS into 10 ohms continuous Speaker impedance nominally 8 ohms Frequency response 3Hz to 50KHz Sensitivity Line 450Mv into 100K for 20 Watts Sensitivity Disc 1.7Mv into 50K for 20 Watts Hum and noise 1.5Mv at full volume level Power consumption 250 Watts Switched IEC socket maximum rating 100 Watts 609 mm wide, 305 mm deep, 230 mm high Weight 33 Kgm Previewed at the September Heathrow Show For a dem contact Paul [email]paul@valve-amps.co.uk[/email]
